Not even two weeks old, and...
someone keyed it. There are 8 parallel lines about an inch long. I tried to use a clay bar on it, but it didn't do any good. I work in a professional building, and I have only taken it to one semi-upscale restaurant. So, I thought I was safe, but I guess the devil comes in all faces.
Anyone has another suggestion to remove it?
What a sad day.
Kevin
What a sad day.
Kevin
that's too bad. i had a similar situation a while back. i didn't find anything that was a good solution that didn't look crappy. ended up taking it to a body shop. it wasn't nearly as $ as i feared. didn't even get to my deductible. but worth it to have it be right. hopefully somebody else will have a better answer.
within the first 3 months i owned my 3GS....the hood had been rolled on outside a bar i frequent, the door dinged, and the passenger mirror kicked off by some A-HOLE. all of this while parking in B.F.E. with no other cars around mind you!! in short....people are jealous as crap. check it......
![](http://i27.photobucket.com/albums/c158/dcbcessnajets/damage1.jpg)
[/IMG]
[/IMG]
to the OP, that's horrible that someone would do that. Did they just scratch the clear coat, or did it go pretty deep? if it's just the clear coat you may be able to get a body shop to buff/wet sand it out. was your temporary tag still on the car? I've always found that's an instant magnet for door dings and potential keying.
Typical sub-human degenerate, the likes of which graffiti other's property and will never amount to anything, much like their cretin parents. Snipers come to mind as a solution!
envy is one of the most negative emotions. envy= sadness + anger. sadness that he is not as good, and anger at himself and you for being the piece of crap that they are. I hate people who do crap like this. I also tend to park far away and I park my car over 2 spots where I work
OKy, soo it all depends, if the scratches got below paint, then u hav to repaint it, if it just got the clear coat, a good rubbing compund, then polish then wax should do the job...Soryy to hear that, thats ehlla fukd up.
Man, that sucks! But I believe in karma....
Do you have pics of the damage? Rule of thumb is if your fingernail can get caught in the scratch, there's nothing that can be done, except for re-spraying. If you can't get it caught, a professional auto detailer (paint correction experienced) can get it out.
do you all notice the same thing?...whenever I make it a point to park as far away as possible with nobody around....there's always like 10 cars that park next to me by the time I come out of the store.
i recently had some scratches on my fender removed. like others have said it really depends on how deep it is. if its a very suddly scratch (which i doubt) you can use a rubbing compound. if its just in the clear, then take it to a shop to wet sand. my buddies auto body place wet sanded and buffed my fender for me to removed my scratches. if its down to the metal and through the paint, the only way to fix it properly is to repaint that part of the car.
I think it went through since I can feel the indentation with my finger nail.
On another note, when I used the clay bar, it may have made it worse. There are circular marks now. I even washed before using it too. I will try to buff it out tonight. I'll take some pics too.
