New Lowered AWD Need Help!
I had a day off yesterday, so I decided to grab my NF210 and bring my car to the shop to get them installed. I head over to EXACT motorsports since they were local, and a reputable shop. After the install the car looked really clean. Couldn't been happier with the job. When I got home, I couldn't wait, had some iforged wheels (20x8.5 N 20x10)I picked up, and decided to put it on lastnight. This morning drove the car out to take some pics to share with you all, I get a light on my dash. At first I thought it would have been the TPS sensor, since the new wheels don't have them on, but it wasn't. It said "check 4WD". I was wondering if anyone came across this problem with there staggered, lowered AWD. Any help is great full. If worse comes to worse, I'll put on my oem equipment back on...
Approximately how many miles did you travel until the computer tripped? I recommend removing the wheels and going to a Lexus dealer to reset it. Your car may be running only on 2WD until you get it fixed. This will prevent the center diff from being damaged.
Planning to replace my tires on the rims, and yes I do feel a vibration, but it's not as
bad as everyone makes it seem. Plus you only feel the vibration at a complete stop. Once you let the brake go, the vibration goes away.
Lexotic Concepts
Did you even consider a tire size calculator prior to purchasing different size wheels for an AWD vehicle? if not for future reference google search the phrase and you will sav yourself a lot of headaches.
Its good to know that if your tire diameter ratios are out of spec the car just switches to 2WD mode.
