Emporer Mark Levinson is not wearing any clothes!
i bought the ML version 3GS for the upgraded stereo but mostly for other options that came with it, much like most have stated.
well, to be honest, i wouldnt settle for anything other than a Glacier Frost Mica with Black interior car. and in 2007 that was the 2nd rarest color combo available. this car had ML, i didnt care about the extra $4K or whatever it was.
I couldn't have agreed more on what you said about the system, the ML is disappointing.
Mine is set with surround off.
Assuming the range goes from -5 to +5...can't recall the range, and too lazy to go out to the garage to check.
Bass - 2.5
Mid - 0
Trebble - 5
Balance/Fade - center
Bass - 2.5
Mid - 0
Trebble - 5
DSP: Off
Balance/fade - Center
Bass +3
Treble +4
Mid -1
You won't be able to increase fm signal performance with the ML system, it will faithfully reproduce the signal input to a degree that is amazing. Fm audio input is poor, output will be poor also. ML will not attenuate or use compression algorithims to mute across it's frequency range . That may not be what you are looking for in car audio, but to my ear, it's among the best factory audio systems I have ever heard.
As far as the DVD-A's are concerned, they are a further source of dissappointment. I've listened to the Beatles "Love" , Pink Floyd "Dark Side of the Moon" and an Austrian orchestra's rendition of Beethoven's 7th, without being impressed with the technology. Sure, CD reproduction is good with the ML, but my home burned CD's seem to do the job as well as the 5.1 productions.
The saving grace is found in the DVD Videos, where Terminator 2 was quite impressive.
I was disappointed in the ML sound in other ways, too. One particular aspect was the bloated bass. I found a way to address that, but it was not by means of only adjusting the tone controls. Had to add a new sub amplifier as well. Glad I did, though.
https://www.clublexus.com/forums/sho...d.php?t=272881
I thought there was a big difference between the ML and non-ML systems. When I purchased my GS the sound system was one of the first things I tested since I wanted a good factory sound system and not have to buy aftermarket parts since I wanted to retain the luxury OEM look. The ML in my opinion shines in the highs and mids, although the lows could be better. And it doesnt distort at higher volumes versus the regular system. I also compared it to my gf's Harman Kardon in her CLS500, and even though it has great lows, the mids and highs dont compare to the ML system. So overall the ML in my opinion is the best system I've heard so far, although I have to agree that the price tag is a bit steep for it.
It is not obvious, but it turns out that the ML system cannot play DVD-A in 5.1 discrete. It is just a basic 2-ch DVD-A player. The only way to hear 5.1 playback is from DVD, as you found work quite well, or you can use your old collection of DTS CDs, too.
Would this assumption be correct?
So then I assume it is better (and more cost effective) to just purchase (or burn) regular CD's, and play them with the DSP function "ON".
Correct. DVD-A discs are typically recorded with PCM or lossless compression, with 96 kHz sample rate and 24-bits. DVDs usually use Dolby Digital and sometimes DTS, which are compression systems similar to MP-3 or AAC, although they use higher bitrates. But since the ML system added DVD-A sort of as an afterthought to the core DVD-V player, they did not find a way to connect the head unit to the amp with a digital means that could support 6-ch 96 kHz audio. So it uses the 2-ch analog lines, same as the AM/FM tuners. The CD/DVD-V player uses the digital S/PDIF connection for both 44.1 kHz PCM or 5.1 Dolby or DTS sound.
Yes. The only other source that will give you sonically equal results would be those 5.1 DTS "CDs" that were made several years ago. Pretty rare, though.
My name is Mark Levinson, the audio designer. My name as an audio equipment tradename is owned by Harman International. Harman puts my name on whatever they want. The reasons for this are an old story but anyone who is interested is welcome to ask me for details. I have never been associated with Harman or had anything to do with the "Mark Levinson" car sound systems for Lexus. I have noticed that neither Harman nor Lexus make any real effort to tell people this fact. The truth is that Mark Levinson the man (me) has nothing to do with the "Mark Levinson" products of Harman including the Lexus car sound systems. It's a "brand name" of Harman. Anyone who wants to know about my real work in audio can email me at marklevinson@earthlink.net.
Best regards,
Mark
Best regards,
Mark
executive matchup
Best regards,
Mark
Best regards,
Mark
Since Harman International owns your trademark name, how do you market the product(s) that you design? Would you be able to tell us what brand you are affiliated with? Thanks.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Hi Mark, welcome to Club Lexus. I was wondering if you had a chance to listen to the Lexus car audio system that bears your name. What is your opinion of them? What would you do differently to improve the quality of the sound system?
I haven't read anything about them recently, but know he was active with redrosemusic.com a few years ago.
Lexus Connoisseur
Best regards,
Mark
Best regards,
Mark
Welcome to our forum. Is there any chance of actually designing an audio system for our Lexus vehicles or perhaps tuning it to really fit the "Mark Levinson" standard?
Thanks,
Ryan
