Just Installed LED DRLs (pics inside)
#46
"The only problem I have heard about LED parking light, may come loose and fall into the headlight housing and that some LED's circuitry will burn out due to the heat generated from the DRL.????"""""
#47
Back up light on the GS300 is a 921. I am going to go with the ones in the link below.
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
I am going to try the ones below in the DRL assembly.Has anyone used these? Any bad things about using these bulbs in this location?
#49
This is crazy,I may be addicted to lights. Its not just with cars,I have them all over the place outside my house.![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Anyway,another question for the guys that change turn signal,marker lights,and directionals. For example,if you change a turn signal which has amber glass and an amber bulb and replace it with an amber led,is it significantly brighter?Does it look that much better or is it a waste of time and money to change them over? Same goes for stop and tail lights,is the look that much different in a good way?
#50
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
#55
"I don't think it would make that big of a difference... Maybe you can try it let us know? "
LOL,I don't want to be the guinea pig.
Yesterday,I put an order into V-Leds but I did not order the colored bulbs.
#60
I got those reverse LED lights in the mail but when I try to install them I would not even get those little nuts thing on the top of the trunk off. How can you get those off so I can install them? any help will be great thanks.
