Headlight issue thread
Old 11-11-09 | 09:46 AM
  #46
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
Originally Posted by RooRa
2006 gs awd is my car and i had a problem when my left lamp started to move up by itself. people thought i was high beaming, and a cop eventually pulled me over. the dealer took 3 days to correctly level the two. thats the only problem i ever had with my headlamps.
also is it me or do the headlights get dimmer?
they will get dimmer over time until the bulbs die. but it shouldn't be linear, meaning it should stay pretty constant for majority of the time until the end when it deteriorate much faster
Old 11-11-09 | 09:49 AM
  #47
LexFather
Guest
Posts: n/a
Originally Posted by I8ABMR
looks like 99% of the people having this issue are people who messed with bulbs and hID kits. I guess I wil not be changing my bulbs. It seems like such an easy mod, but not if its going to bite you in the ***
I don't see that, seems a lot are people with stock cars.
Old 10-02-10 | 08:25 AM
  #48
masterchri's Avatar
masterchri
Sorry to bring back an old thread but it seems that no on has really found a solution to the problem. I just noticed the same issue tonight.. Driver side HID goes out.. turn it off, then back on and all seems fine.. but I have to do this every time I drive at night... really irritating..I have an 08 GS350..Someone shed some light on the situation please!!!
Old 10-29-10 | 09:11 AM
  #49
bolido's Avatar
bolido
My car is actually doing the same thing every night now. Driver side headlight. Will ask the dealer if its something with the ECU.
Old 10-29-10 | 09:45 AM
  #50
johnnunez2's Avatar
johnnunez2
got same problem. but with passenger light.
Old 10-29-10 | 09:49 AM
  #51
IXI187IXI's Avatar
IXI187IXI
it seems like theres a thread like this on a weekly basis now. make sure your connections are tight for the bulb. if they are, try swapping the bulbs to the other side. if the same headlight is acting up, it could be a bad ballast. if the other headlight is doing it now, it could be a bad bulb.
Old 11-06-10 | 04:41 PM
  #52
nos fed's Avatar
nos fed
My car is i the shop right now for this issue. My passenger side headlight would turn off & then turn on again with a quick on/off flick. At first i thought it was the bulbs, so i purchased new Philips 6000k bulbs. Those only lasted 2 weeks so I took my car to an independent dealer to see what they'd say. Lexology tells me it's the ballast & I need to replace the entire headlight assembly since the ballast isn't replaceable in the OEM assembly(???). Does anyone know where I can find a good aftermarket headlight kit? I refuse to pay $1200 for a Lexus headlight.
Old 11-06-10 | 04:45 PM
  #53
GS4_Fiend's Avatar
GS4_Fiend
Doesn't the 3GS uses the same ballast brand as the 2GS?
Old 11-07-10 | 12:10 AM
  #54
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
dunno if same brand, but i would think it's not the exact same one
nos, look for ballast from junk yard cars i say
Old 11-08-10 | 09:48 AM
  #55
RooRa's Avatar
RooRa
Hi,
I have this problem again, first it was the driver side headlight moving up by itself, now my right side dies on the highway. sometimes it doesnt some times it does. i took pictured and even a video of the lights not working. one time both headlights went dead. Im going to take it to the dealer and get everything under warranty. last time i went they gave me this " we could not replicate the problem" so this time i have proof.
they told me it would be under warranty and everything should be fine. im on stock btw.
Thanks,
Old 11-08-10 | 01:50 PM
  #56
bolido's Avatar
bolido
The dealer ended up replacing the bulb. It's been a few days and the headlights are ok so far.
Old 11-08-10 | 08:28 PM
  #57
LB23's Avatar
LB23
I hate this!!!
I have other cars with xenons and never a problem!!!
Old 11-09-10 | 11:28 AM
  #58
nGeee's Avatar
nGeee
i have this problem as well, i am running 5k low, parking and fogs. my left low beam lights also does a small blink, like the fuse is weak or something and it turns off, i would sometimes turn on the lights and look at it.
1. could it be the ballast that takes up all the voltages, like another member mentioned?
2. could it be the batteries after running 4-5 years that hasn't been replaced?
Old 11-22-10 | 01:51 PM
  #59
nos fed's Avatar
nos fed
hey guys, this issue still hasn't been resolved for me. you wouldn't believe all of the bull***** i've gone thru so far trying to get an HID kit for my 06 GS300. It looks like the problem is the ballast (as mentioned earlier in this thread). Does anyone know of an HID kit from a reliable source? I'm not having much luck with this & I'm surprise I haven't been pulled over yet *KNOCK ON WOOD* It would be an additional help if the vendor was close to CA for quick shipping. Let me know. Thanks!
rominl, i thought about going to a junkyard, but i figured "new" headlights from a junkyard would cost more than a ballast kit ($150 +/-?)
Old 11-22-10 | 02:11 PM
  #60
IXI187IXI's Avatar
IXI187IXI
nos fed, does your GS not come equip with HIDs? I thought all 3GS' had HIDs? If you need a ballast, check ebay. Their pretty cheap. Any where from $60 to $90
