Tire Pressure
Old 12-15-08 | 04:37 PM
IStoGS350's Avatar
IStoGS350
Default Tire Pressure
So this is probably a dumb question, but can someone tell me what tire pressure is optimal for my 245/35 R19's?
I can handle the heckling, just help me out. :-)
Old 12-15-08 | 05:26 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
there is no "optimal". technically factory already has a spec for the tires, which is 32 or 33psi. that's what you should set it to
but in general, people recommend higher psi for larger rims with lower profile, mainly to help protect the rims themselves. on 245/35, personally i think 35 to 38psi max is a good number
on my super rubber band 20s, i go 40psi just in case
Old 12-15-08 | 05:49 PM
ECUgs430's Avatar
ECUgs430
im always afraid of blowing out a tire above 37. not the best roads around here.
at what point does higher tire pressure increase the risk of blow outs? >40psi?
Old 12-15-08 | 06:25 PM
vietdeluxx's Avatar
vietdeluxx
I keep mine between 35 and 40... At least thats what the discount tire guy told me
Old 12-15-08 | 06:26 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
most tires have max pressure of 51psi or so. having it around 40 i don't think it will really increase the chance of blow outs. i mean, if there are nails or so, it will blow out your tire anyway no matter the pressure. if you are talking about blowout from heat, then 40psi is nothing
Old 12-15-08 | 06:54 PM
IStoGS350's Avatar
IStoGS350
Thanks guys!
Old 12-15-08 | 07:15 PM
I8ABMR's Avatar
I8ABMR
I am running a 30 series profile so I am always at 42 psi
Old 12-16-08 | 06:07 AM
The G Man's Avatar
The G Man
I use to have a set of 45s, the tire guy told me to keep it at 38 to 40 PSI.
Old 12-16-08 | 08:06 AM
IXI187IXI's Avatar
IXI187IXI
wow thats pretty high. i usually keep my tires around 32-33 psi. maybe that could be the reason my low tire light always comes on lol
Old 12-16-08 | 11:08 AM
Wronglane's Avatar
Wronglane
In all my tires on every vehicle,I run the maximum pressures as stated on the tire.This helps with fuel mileage also. If you drive in snow,I would lower pressures though.
Old 12-16-08 | 12:30 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
max pressure stated on tire?!?!?! that sounds like a pretty bad idea.
Old 12-16-08 | 12:35 PM
IXI187IXI's Avatar
IXI187IXI
thats pretty common and i think its a good idea so you dont have someone over fill the tire and cause a blow out. i know all my z rated tires usually say "max 45psi" on the sidewall
Old 12-16-08 | 12:50 PM
slk_dds's Avatar
slk_dds
I was reading the Car & Drivers, it stated that if you add additional 5psi (max) to the tire, it would increase fuel effenicy.
Also our toy is head heavy (52:48 I think), my tire shop service advisor recommend adding 2 extra psi to the front to cancel out head heavyness!!!
If anyone is curous, I am running 39:37 psi on my toy.
Old 12-16-08 | 12:56 PM
The G Man's Avatar
The G Man
If 2 PSI difference can cancel out a car being front heavy, then all those design engineers at Porsche are wasting their time trying to design a car with perfect weight distribution
Old 12-16-08 | 03:59 PM
socalJD's Avatar
socalJD
^ LOL, those porsche engineers spent the last 3 yrs designing the VW Routan & Tiguan. . .
Quick Reply: Tire Pressure
