Extended warranty seems to be worthless
I have extended warranty on my 2006 gs430 until 100k. They claimed it to cover anything wrong with the car from "head to toe". This is untrue. I brought the car in because my left headlight was going off by itself while I was driving. It started to happen regularly (every night). They say the problem is with the headlight assembly ( moisture got in some how). They said its not covered. Why? Its not a wear or tear product.. the part alone is $1100. 1100 bucks + labor to fix a headlight. Extended warranty proves to be worthless.
If the headlight was not modifed or work on before and mositure got in there, then its a factory defect and should be cover. I would call up Lexus headquarter or try another dealer.
This is very disconcerting to see (and I'm sure way more disconcerting to have to pay for - sorry to read about your situation). Is this the Lexus CPO Warranty?
The exclusions are supposed to be the following
The following components are specifically excluded from coverage under the Lexus Certified Pre-Owned Limited Warranty:
Standard Upkeep Items:
accessory drive belts, batteries, filters, fluids, heating and vacuum hoses, lines and tubes, tires, spark plugs, windshield wiper blades (rubber component).
Wear and Tear:
Examples include brake pads, rotors, shoes and drums and manual clutches.
Body and Interior:
bumpers, carpet, chrome, dash cover and pad, door trim, handles, fabric, glass (including windshield), headliner, hinges, interior and exterior trim and moldings, cupholders, ashtrays, covers and vents, lightbulbs, nuts, bolts, clips, retainers and fasteners, paint, rust and corrosion damage, seat covers, shiny metals, weather stripping.
Accessories:
any non-Lexus accessories or modified components, including but not limited to wheels, radar detectors and cellular phones.
Other:
any component which has not failed, but that a repair facility recommends or requires to be replaced, repaired or adjusted.
http://www.lexus.com/cpo/overview/warranty.html
I can't figure how the headlight assembly would possibly be excluded???
Wear and Tear:
Body and Interior:
Accessories:
Other:
i wonder if moisture in headlamp is common. when you change the bulb, doesn't air get into the headlamp?
on my older lexus, there was always water vapor inside the headlamp shell.
OP, let us know if anyone eventually covers your shiet under warranty. sparked my curiosity.
Wear and Tear:
Body and Interior:
Accessories:
Other:
Wear and Tear:
Body and Interior:
Accessories:
Other:
not even rust is covered.
they should just reword and simplify the whole policy:
The following components are specifically excluded from coverage under the Lexus Certified Pre-Owned Limited Warranty and Extended Warranty:
EVERYTHING!
JUST FORK OVER THE $2750, SUCKER.
EVERYTHING!
Forum Administrator
So the dealer told you first it was covered (this thread) and now they aren't?
Have you had any accidents to the the front of your car (or did you run a carfax /check dealer service records when you bought it to see if had been in an accident)? Did you put in any aftermarket HID bulbs, other bulbs kits, etc or is it totally stock? Please share more specific reasoning the dealer gave you on why it isn't covered.
So where do I call to get this resolved. It seems like it should be covered right?
BTW the headlight has never been modified in any way, and No there has never been any accident in the car. Perfect car fax. I have never even touched it. So embarrassing to have 1 headlight off while driving in a 50k lexus!
^ Did you take it to the dealer that you bought it from ??? If not, take it back to the original dealer, even if not covered by ext warranty, they should cover it as 'good will'. Otherwise try another dealer, I've found warranty work from Lexus to be hit or miss, one dealer will deny warranty coverage while another will take it. Good luck.
CALL 1-800-25-LEXUS...tell them you want to file a claim and would like to speak to Mrs. Celeste...be nice and professional about the situation to her. Tell her how you feel and provide everything you just told us...she will help you out. I went over 50K miles and she still warranty my rattling on my dashboard, rear view mirror and rear park sensors.
That would **** me off and I would go to another dealership. Moisture in the light assembly is BS and Lexus should take care of it. I am going to be extening mine at the next oil change or the one after that. Thanks for the input. I will be honest and say my service advisor has never ceased to blow me away with the help and service quality. I have yet to be burned by lexus, but I am sure tey are aware that things like this will cost them customers. 1 angry customer will usually negate the praise of 6 happy customers
