Squeaks and dash noise
Got mine back this friday...so far NO RATTLES and im happy with the repairs. I know a lot of you guys don't want the dealers to tear the dash apart but let me tell you...Park Place Lexus did an excellent job of putting everything back. My car is so quiet and the ride is smooth...this is how a Lexus should be !!!
my dash has been out before and will be replaced under warranty. I ha d an area of discoloration so they are gonna replace the entire unit. Hopefully this time they line the back of the dash with felt tape like there is no tomorrow
ps close to 2" drop and the 30 profile tires dont help the vibration issue as well. I feel for the members in LA that have their GS's lowered on dubs
it's gonna be a vicious cycle.
everytime you hear a click, you're gonna ask them to take apart your dash. The clips will get worn out, and your dashboard will just get looser and looser, creating new rattles.
it seems all they do is stick felt on everything, because it's hard to pinpoint the source of the noise.
since rattles are gonna develop over the next 50000 miles, it's just better to stick foam in the gaps, and wait till the end to have everything fixed at once.
you guys are torturing yourselves.
RudeDoggy, I had the exact same issue. I had the dealer fix the rattle in the winter, come summertime, the rattle re-surface as ticking noise. Maybe there is some truth to what your SA is telling you. My guess is that Lexus will make a stand on this rattle fixing interval soon, it much be costing them a lot of money to have owners comes back again and again to take the whole dash apart. All these felt tapes and foams are just temporary fix in my opinion. Its actually stretching those plastic dash clip out and the rattle will come back sooner or later, and foam and felt tapes dont last forever. Is there a clip design that Lexus is using to replace the old one, can anyone confrim this?
Noises fixed, but radio loses stations
Hi,
We had our new GS's rattles and dash creaking fixed, but now the radio loses stations intermittently. Its back at the dealer now. Anyone had this happen to them?
Henry
Henry
lexus knows they fuct up the build on this car, and they dare not alter their policy about fixing it.
I've read Audi, on the other hand, only warrants rattles for 1 year or something. Better make sure you're driving on paved road
i also have this styroform noise from my dash, and yes, i don't want the dealer to tear out my dash making things even worse.. this happened to me before with my g35. how long was your car in the dealer? what were the parts back ordered to leave your car such an extended period of time?
Lexus has a very good service department, but do you really think that Lexus would keep appling the same TSB to the same problem over and over again if it didnt fix it the 1st time. If there is a new TSB for the same problem, then thats a different story.
there are a few reasons why a tsb would fail to fix a problem, e.g the tech did a sloppy job
They're getting paid flat rate, and working against the clock, so some couldn't care less. That is why i refuse to take my car to get interior noises fixed unless they're really bad and coming from all over the car.
a phone call to lexus HQ usually solves the problem.
A few good example of tsbs which fail to fix the problem from the time to time is the GS's dash rattle and squeaky brakes.
All dealer work on a flat rate when it comes to warranty work but they still to to justify the work and have to follow Lexus's warranty policy, otherwise Lexus will not pay them anything.
You live Cali, so your rattles are not that bad. If you can hear my dash board in the dead of winter, you will understand what we are talking about, but thats not even the point, those rattle should have never been there to start with in a brand new $55000 car.
Originally Posted by thomastan
These all all the items they change for my front dash rattles below:
(1) NOISE KIT
(1) LOVER SUB-ASSY, COW
(1) STAY, INSTRUMENT PAN
(7) CLIP, INSTRUMENT PAN
CAUSE: EXCESSIVE BODY CLEARENCE/REFER TO TSIBL-SB-0040-08 REMOVED DASH PAD AND INSULATE PANEL CLIPS/HVAC DUCT/A-PILLAR GARNIS & REPLACE COWL LOUVER NV8040 INSTRUMENT PANEL RATTLE R&R INSTRUMENT PANEL SAFETY
(1) NOISE KIT
-RE-RE front dash panel. Adjusted. Installed insulation secured to reduce/eliminate noise as per TSB.
It looks like you got a more comprehensive fix. I wonder what the "noise kit," "lover," and "stay" are. Anyone able to provide some insight into this? And with my last dash job, does "installed insulation secured to reduce/eliminate noies as per TSB" mean they padded the clips? I'm not quite sure what that descriptor even means.
noise kit is just a box of felt tape.
they go buckwild and plaster the tape everywhere, every crack, crevice, anything that has a taping surface.
it's ugly
The G Man, interesting to hear your experience with the squeak/ticks. I see you are from MA so your winters are similar to mine (maybe slightly warmer than us?). I am starting to wonder if I should take my chances and take it in to get it fixed once and for all (they keep bugging me to come in so they can replace a vent they broke the last time they adjusted my dash...).
