Who has Dynoed their 3gen GS?
Went to get a Dyno today and the car doesnt like to hold gear for nothing. Only mode I was able to get the car to hold was Snow Mode.
Just curious who has done this and what where your results? What did you do to get the car to hold gear![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
I have an 06 GS430...
Thank you
Thank you
in normal or power mode the car wants to shift even if its in the manual mode. if its in Snow mode it will hold the gear the whole way. either something is wrong with my car and we did the dyno right or there is another way to do this?
I had an ISF owner with me and his car...they just wanted my car off and his on
I must have been asked by everyone if they where putting the F on the Dyno![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
hoping someone has done this so I can compare.
Thank you
Thank you
so i was just at the dealer and all is good with the car, no codes and A/f is perfect.
they are thinking its due to all the stability/trac/abs/ect....since the car sees the front tires are not moving.
I don't know anyone have any other ideas? didn't someone Dyno for an intake or even an exhaust?
Yeah, this was really odd. Didn't seem to matter what mode the car was in it would behave differently.
In manual mode it would start the pull OK, get to ~5000 RPM and then suddenly downshift with the revs shooting up. In auto mode it would want to downshift as described. Couldn't keep it from downshifting even when starting the pull around 3-3.5K. Finally snow mode seemed to work but the output seems "off" from what a 430 motor should put down. I was expecting close to what my old GS400 did stock (~235-240) but it didn't seem to match.
Have other successfully had one of these on the dyno? I've heard of some cars that would sense the fronts not moving or lack of airflow cause tons of issues with getting max power but I did not think the GS430 was one of those.
I did a web search on lexus + vsc + dyno, and found that this may actually be what you need to do. One page even said this is referred to as "dyno mode"
1. Start the engine
2. Engage the parking brake
3. Depress and release the brake pedal twice
4. Disengage the parking brake
5. Depress and hold the brake pedal while engaging and releasing the parking brake twice
6. Release the brake pedal
7. Engage the parking brake
8. Depress and release the brake pedal twice
9. Disengage the parking brake
The Check VSC and Traction Control indicator lights come on when the systems are disabled (the steps are a pattern and you only need to continue until the lights come on). It resets when the car is subsequently restarted.
1. Start the engine
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Well it's worth a shot.
The IS-F didn't hit the dyno that day. The results in the other thread are from another IS-F.
You gotta do what you gotta do. The Trac Off button only works up to 35 MPH on the 06.
I tried it for kicks, and it's really not as bad as it reads. It's a pretty quick "Press - tap - tap, switch, press - tap - tap, switch"
Oh BTW, it does have to be done in some short period of time from starting the car.
