My GS is not low enough! HELP!
#31
You car has a nice drop and I believe you have a body kit too. If you go much lower it might have problems going in certain areas, especially if you are is daily driven.
My car is on Tanabe pro 5 and I can go a lot lower but its a pain to even get out of my slopped driveway and some places with dips.
#32
#35
Go with a coilover that has an adjustable shock body like JIC, HKS, Megan, etc. Tein is garbage IMO. Terrible design that gives you very little suspension travel when you slam it.
BTW, if you want to go lower, go with something else and don't listen to other people. A few millimeters is the difference between lowered and slammed. Setting up a great stance for your car is something often overlooked.
#37
exclusive matchup
with tein ss or cst, when you lower the car, travel is less, but it helps protects the car. i guess that's partially why my gs is low but i hardly bottom out or rub?
#38
but at the same time though, with a coilover that you can adjust shock body, problem is if you maintain suspension travel and lower the car a lot, when you hit dips, the travel itself can easily bottom out your car. had my share of problems with tein flex which had that feature
#39
I sill say to try the JIC's. I have an older set of Tein's on my 2gen and the ride between the two is night and day. Even though my 3gen is still on stock wheels and tires, there's no comparison between the two. But if your really ballin, you can always get the Roberuto...then you'll have the best of both worlds!!!
#40
exclusive matchup
well, could be the reason, coz' your travel is much smaller now and it gets quite a bit stiffer than stock (or original height)
i still remember back in the 2gs days, someone with a gs400 got the tein flex, lowered the car a lot, but mainly by adjusting the shock body. the end result was he was bottoming out the whole car very often, denting the under body at various places. he ended up going to the shop, adjusted the shock body again, and lowered the car by reducing suspension travel. and he didn't rub again
i would also agree jic coilovers are much more performance oriented, actually they have always been. and i believe the spring rate on jic is pretty high? can't remember exactly.
#41
#42
St Vincent,
Nice looking whip. I see you are in the DMV area too & have an AWD GS like me ('06). Did you go with a simple spring change out or adjustable coil overs? Who performed the installation for you. I'm based near Pohanka Lexus (Chantilly) & the said they'd install whatever I wanted, but could not pin down a price.
#44
i dont know why im in this part of the forum...
i think your car looks great as is.
if you must go lower have you thought about a youzealand ss kit?
looking at the youzealand website there is a application for your car.
it lowers your car more but retains the ride from what i read.
http://www.youzealand.net/LEXUS/lexus.html
#45
St Vincent,
don't know how u guys manage to drive on the street, speed bump, etc..
