My GS is not low enough! HELP!
I dont know what it is, but for some reason my car doesnt seem low enough for me, especially the rear, it annoys me a lot. Maybe its my mind playing tricks on me but I wish it could go lower. Im currently running Tein SS's, and it is completely maxed out with no threads left, and it has settled. Is there another set of coilovers that go lower than the SS's? Airbags are not an option right now. What do you guys think, is it low enough or should it be lower? Also, if I put 18in. wheels on my car will that allow it to go lower since I am using 19's right now? Any input would be greatly appreciated.
Most current picture:
NELOC Moderator
That car seems low to me, but i can see what you are talking about... it could rest a little lower epically the rear as i can see the gap in the fender area. You should of gone with a different set of Tein CS with a lower drop as oppose to the SS (i have tein ss on my 2nd gen gs and the rear is not as low as the front). Air suspension should give you what you are looking for.
i actually think you should go with a larger wheel, like a 20" and a more aggressive wheel/offset. it will give the illusion you are lower. plus it will fill the wheel well more, and tuck a little more.
or you could build a realyl heavy sub box for the trunk. haha
Thanks for the inputs guys, so from what it seems JIC's go the lowest out of all the coilovers? Since 18's wont make a difference ill probably go with 20's next to give it that "illusion". But yea, the rear isnt as low as Id like it to be. As for my windows, they are tinted, should I get it darker?
