so did you do what GS350on22s said? can you confirm there are no vibrations anymore? if so, this would be the solution for all AWD owners who want to lower!
who ever is dropped on awd springs hold the traction button in the center console down for 4 sec till the lights go on and give it a drive. let me know what goes on k. try it out..
so is it just a larger drop because of the higher ride height of the AWD??? I have a good friend in NYC ,who is a member , is having vibration problems with his rwd springs. Do you guys think that the springs can produce vibration???? I am not sure. I told him that I thought that the main difference in the springs is going to be the amount of drop.
do these springs give an aggressive drop???? i am on 22s in the summer
adam it gives a 1.7" drop in the front an 1.2" in the rear. I think its gonna be to much of a drop with the 22's man. You already had rubbing and had to do fender and even bumper clip mods to use the very conservative Tein H techs. I am concerned you will not be able to use your twinkies
what exactly are you trying to find out from this test?
there is a button right in the center console, that traction button. i hold it for like 3 seconds and 2 lights come on. when those lights are on the car has no vibrations and when its off i vibrate. i don't get it
I don't have that button on my year. I thought only the RWD cars had em.
I think it's only 2008+ that has that. Mine is is a 2008 AWD and I have that button.
For the record, pressing the traction control button once turns off TCS but leaves VSC on. Holding the button down for 3-4 seconds will turn off VSC too (not really a great idea here with all the snow on the roads....).
look up the ecu upgrade thread i posted in the 3GS forum. someone posted the details to the pedal dance. you apparently need to do this if you are going to do a dyno (to stay in 3rd gear)
