DVD/Nav Bypass
DVD/Nav Bypass
I know thes topic has been covered before. I just had the dealer install my XM and Vaistech piece. They would not do the bypass because its not legal for them to do so, one of the techs there gave me his number, but its hard to get in contact with him. I want to watch movies and enter data into the Nav as I am in motion, do you guys know of a shop will do it for me in Northern NJ. I know in girls RSX, we had the wire grounded out and we were able to control everything while in motion. Please help, I have already had this installed for 2 weeks and want to enjoy it while driving home from work. I am not confident enough to pull apart my unit and do it myself. Thanks in advance.
exclusive matchup
you can't just ground wires, you need to put switch in order to get everything right, but even so it's 30-40 seconds. you can get the override module from prestigious, more pricey but plug and play and no time limit. so it's a toss. if you want more info you can email them at chung@prestigioussociety.com
^ No time limit How did you get that to work??
They way I see it both void your warranty. You can have a local member help you do the Navi Hack or you can get this PNP kit and install your self if your up to it. Its a very easy install. Just did another one this past weekend for a local member.
executive matchup
as rominl suggested, get the plug and play override kit from prestigious society. it's easy to do for any aftermarket car audio techs. and of course the dealer won't do the bypass, that would get them in so much hot water from lexus HQ, it's not funny.
and a disclaimer here, you should never operate your vehicle in an unsafe manner, including watching movies or making phone calls while in motion. i got the override kit for the front passenger to input the navi destination while in motion (to save time). always use common sense, and don't put yourself in a position where you can be blamed for liability if you get into an accident
exclusive matchup
i have the PnP kit in my gs350 and there is no time limit. i can override the system for as long as i want (without shutting off the car of course).
cutting wires void your warranty right the way, that's for sure (and i have seen 2 is350 in that category). but with the PnP kit, the beauty is that if anything happens to your nav or radio, just take the kit out and go back for warranty work, plain and simple. there is no wire cutting so it's all factory. plus the PnP is a completely passive system, knowing how the module works, i can't see how the module itself can cause major problems to the nav
are you referring to the DVD while in motion or entering of destination. The DVD works as long as you dont turn the car off. I have the same kit but the input while in motion times it self out. If yours doesnt do this I would like to know what you have done to prevent this?? This is an issue with all the Lexus models to my knowledge 07 models and forward.
exclusive matchup
the problem on 07+ (actually 06+) is problem on units that aren't from prestigious as far as i know
I have the same kit they sell but not from them, got it from a member here. So is there a switch on it that I missed? Installation was pretty straight forward.
Edit: I guess this kit could have come from anywhere unless they are the only supplier? I know its the same kit. I also thought I read a thread not to long ago where you posted that it was getting ~45 seconds? Both you and Flipside009? I will have to search for it and review it again. Basically mine is the same as it was with the wire hack in the IS350 where it gives only so much time, turn it off then back on to replenish the time, to enter the destination.
okay here is the thread, so I went back and you had posted that every car you tested got ~ 45 secs (last few posts in the thread). Then I see yours where you get ~ 5 min? Was that on the LS only or on your GS also? I am curious now. I am okay with it as is but if I can get more time its less work
https://www.clublexus.com/forums/gs-...-works-18.html
Thank you!
Thank you!
exclusive matchup
iirc i think it was like 299 or so. don't even ask about the one i got for the ls460l. it was the first unit ever imported and i paid so much for it
yes it was 45 seconds but later on prestigious issued the fix. but seems like they are tight lip about it, probably to avoid some others from stealing the info for their benefit
