roll the fenders
my front was rubbin a lot after nf210 so my shop rolled the fenders in the front but it just looks terrible...anyone know how to fix this problem???
u have to find someone good at rolling. i did myself with the rolling tool. it works perfect. but u will need to cut the fender liner a little bit. good luck. i have a 08 gs![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
executive matchup
it depends on wheel offset and/or tire size. if either one (or both) is not selected properly, you will have rubbing issues. lots of people lowered with large wheels have no problems. as long as you do your homework in selecting a wheel package, you will be fine.
You can have a body shop fix it. Theres a guy in Miami that does a very good job at rolling fenders. What shop did you go to?
when you guys say cut with what i have minor rub rear tire when i hit bumps i want to do it myself i have a 06 300gs awd lowered with road magnet springs 245/35/20f 285/30/20r
shave the fenders down. You can get a power tool to sand them down but I suggest to get someone to help if you havent done before. You can search YouTube and there are many videos of people rolling fenders and shaving them so you an get an idea. I would shave them over rolling from past experience.
I rub in the front when reversing and turning. The tires rub on the inner plastic lining (it sounds terrible but not bad) but not on the fender. I want to install 245/30/20 tires in the front to reduce or eliminate the front rubbing and 295/25/20 in the rear. This way I can get the rolling diameters back to stock (25.8", from 26.7"). However, I will probably need to roll the rear fenders.
