5K, 10K, & 15K service. what is done?
here's a list of the maintenance schedule from lexus.com for the gs350.
30 day or 1k
insepct body/chassis
check for fluid leaks
road-test vehicle
program lexus personalized settings, if requested.
6 month or 5k
oil and filter change, reset reminder light
rotate tires
visual inspect brakes pads and rotors
road test car
additional maintenance required if you drive primarily under the following conditions:
driving on dirt roads or dusty roads:
inspect axle shaft bolts
insepct ball joints and dust covers
inspect engine air filter
insepct steering linkage and boots
tighten nuts and bolts on chassis
12month 10k:
rotate tires
measure brake pads and rotors
replace air conditioner filter
inspect pads and rotors
road test car
plus the additional inspections as in the 5k if needed.
18month or 15k
oil and filter change, reminder reset
tire rotate
clean air conditioner filter
visual pads and rotors
road test car
inspect the following: axle shaft boots, ball joints dust cover, body, brake lines and hoses, engine coolant, exhaust pipes and mountings, front diff oil (gs350 AWD), rack and pinion assembly, rear diff, steering linkage and boots.
additional inspections if you drive in a dusty dirt area:
engine air filter
tighten nuts and bolts on chassis.
The guys said that I need to bring the car back for the 15k service at least. After that I can do the other services on my own.
from what i see on the list I can just give this check off list to a friend and I'm confident tthat it will be cheaper than $300-400. Cause all i see are visual inspections on there. Nothing major IMO. maybe the air conditioner filter. but i'm pretty sure the board can tell me how to do that myself.
30 day or 1k
road-test vehicle
6 month or 5k
rotate tires
road test car
12month 10k:
rotate tires
road test car
18month or 15k
tire rotate
road test car
engine air filter
I wonder why price differ so much between each Lexus dealers in So Cal.
executive matchup
executive matchup
I wouldn't take it anywhere other than DIY or dealer to change oil. These other places they don't change the washer when they do the oil change. Also they tend to over tighten. Causing the oil pan to have a bad threadwear and leakage.
