Tires rubbing...front or rear??
Old 02-01-09, 04:49 AM
stvincent
stvincent's Avatar
i have a slight rubbing from the front, only when i turn the wheels all the way in reverse or a large dip, but i'm running 20x8.5 with 245/35/20 which is bit larger than the oem spec. donno what's really causing your rubbing.. just sharing some info..
Old 02-01-09, 05:58 AM
passnu2
passnu2's Avatar
^I had the same issue on my IS. That is the plastic liner. nothing to worry about
Old 02-01-09, 08:36 AM
rominl
exclusive matchup
rominl's Avatar
you are rubbing because you are running overspec tires, and when turn all the way (hard lock turns), the edge of the tires are rubbing the front/rear (NOT the top) of the front wheel well
vredniykot
06-18-19 10:37 AM
jvjr9902
07-20-15 06:00 AM
Stew4HD
Suspension
03-28-14 03:51 PM
migoylim
07-22-12 01:19 AM
Naushaud
Suspension and Brakes
20
07-09-07 04:29 PM
Quick Reply: Tires rubbing...front or rear??
