Exhaust tips
Old 02-10-09, 02:55 PM
bryanc182
bryanc182's Avatar
Default Exhaust tips
Just bought some from Sewell Lexus....they said they slide on...only problem is....how do i get the ones that are already on....off???? Can i do this myself or do i have to take the car into a muffler shop???
As always, any help is greatly appreciated!!!!
Old 02-10-09, 04:20 PM
sonikbo0m
sonikbo0m's Avatar
just pull really hard.
heheheh.. why did you need to change the tips?
you can use like a rubber hammer to bang it out, but just be careful of course. new ones would be put on the same way.
Old 02-10-09, 05:40 PM
bryanc182
bryanc182's Avatar
Mine are dull.....i like the shiny chrome!!!!!!!
bling! bling!
Old 02-10-09, 05:54 PM
Coffee87
Coffee87's Avatar
Just did this myself. If you look inside you can see the small pressure points where the tip is held onto the actual exhaust pipe. I just used a long screwdriver and carefully bent the tips until it loosened enough to pull off. Didn't have to use a hammer at all and it took about 5 minutes to change them out. Really easy.
Eagle1x (03-13-23)
Old 02-10-09, 08:34 PM
vietdeluxx
vietdeluxx's Avatar
Hmm, I was thinking about replacing mine too so I took a quick glance a few months back but I thought it was welded on so I didn't bother it again. If this is true, than I will go get a tip and replace the old one. Thanks for the advice. Do you have any pics of your tip? Where did you get it from? Thanks
Old 02-11-09, 05:42 AM
Coffee87
Coffee87's Avatar
Nope, definitely not welded on. I bought them off amazon. They are the Borla exhaust tips (part #20156). I will get some pictures this weekend after I wash the car - waiting for the rain to stop.
Old 02-11-09, 07:34 AM
bryanc182
bryanc182's Avatar
DId you go in from the front of the exhaust or from behind? I tried taking a screw driver from the back of the tip, but the muffler gets in the way....so i couldn't reach it....
Old 02-11-09, 08:18 AM
Coffee87
Coffee87's Avatar
I went in from the front (outlet) of the exhaust. If you shine a light from the back you can see in there really good and see where the tips are held on.
Old 02-11-09, 09:21 AM
bryanc182
bryanc182's Avatar
cool...i'll try that...
gracias amigo!
Old 02-11-09, 10:07 AM
retrospexo
retrospexo's Avatar
anybody ever fit on the twin (er... quad) tip exhaust tips on their mufflers? do you need to cut the area to make it fit? ...is it possible to do so w/o cutting? thanks!
Old 02-11-09, 11:44 AM
ndk83
ndk83's Avatar
^^^ im trying to do this on my IS, yes u will need to cut the bumper, the biggest tips you can add are single S2000 OEM tips. For quad tips u will need to cut the bumper. Sides if u find some that fit without bumper modification then its probably too small looking
Old 02-11-09, 12:49 PM
maying856
maying856's Avatar
The tips for our GS's are not welded on, theres just two points that you have to losen with a flathead and then you pull it out. Really easy, just takes a little strength and time.
Old 02-11-09, 01:24 PM
bryanc182
bryanc182's Avatar
where are the two points located????
I'm diggin your tips...what are those???
Old 02-11-09, 03:23 PM
Jaylex
Jaylex's Avatar
x2 I'm feelin those better than stock. I have to replace once of mine. I took my car to the dealer and I noticed a few days later one was missing. They wouldnt replace it even though they worked on the exhaust hangers (I was hearing a wierd vibration noise) Needless to say I need to replace them before I get my wheels and coils installed to complete the effect...
Old 02-11-09, 03:34 PM
djentee
djentee's Avatar
maying, love the tips on the GS.
Quick Reply: Exhaust tips
