what kind of oil to use
#32
Since I found out my dealer uses conventional oil, I have switched to full synthetic. Also, my two previous BMW's used full synthetic and required oil changes only every 10 -12,000 miles, per the computers. I thought this interval was too long, and changed oil every 7500 miles. However, now that I'm using full synthetic on the GS, I also plan to change oil and filter every 7500 miles vs. 5000.
#33
executive matchup
i plan on following lexus's recommended service maintenance interval. if i am getting my oil changed regularly, does it really matter whether it is conventional or synthetic?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#35
I bet all those little Corollas in the Toyota commercials with 300,000 doesn’t use synthetic oil. The oil companies spend a lot of money on marketing, unless you live in extreme cold or hot climates, synthetic oil is extra protection you do not need.
