The high-mounted (AKA the third) brake light.
Does anybody know how to remove it. I want to tint my windows, but before that I want to remove the light, so they do a cleaner job tinting. Also, there seem to be some sort of an eye-looking sensor under the light, looking to the rear. What is it for? And will the tint affect what ever function that sensor has?
exclusive matchup
they shouldn't have to remove the brake light in order to tint the window. just need to make sure your shop is a good one. my shop installed tint without removing that
that sensor is the light sensor that helps adjust the brightness of your gauge cluster under different lighting condition
Same here... they were able to tint my whole back windshield with one piece and without removing the light... ask your shop before they start to make sure they can do it.
Finally figured out how to get the stupid light off. The instructions in the manual are completely wrong. If you ever need to do it here it is:
Pull the front side (closer to the seat) of the upper shell straight up. You can helpit by prying the two (lower and upper) halves apart with with a knife. It easily pops out. Then slide the upper shell of the light about 1/2 inch forward, toward the seat, to release those claws. Then disconnect the wire plug and that's it.
