Cracked passenger side mirror
Old 02-12-09, 08:42 PM
bozer
bozer's Avatar
Default Cracked passenger side mirror
I've got a nasty crack in the glass on the passenger side mirror. Anyone know how I could go about replacing and how much it will run me?
Old 02-12-09, 09:03 PM
EyeKutr
EyeKutr's Avatar
Bozer
i dont think they sell just the mirror, it comes as an expensive assembly, look at ebay for a mirror assembly, you can disassemble the glass part and install it, ebay mirror assemblies are quite economical....I checked since I took mine apart recently and was checking out my backup options, search for the DIY side mirror LED thread and youll see how to take off the mirror, you can do it without taking the whole thing off the car...
Old 02-12-09, 09:47 PM
rominl
exclusive matchup
rominl's Avatar
they don't sell just the cover? that'd be bad
if you can't find it cheap, imho maybe time to just get the aftermarket turn signal ones
Old 02-14-09, 10:01 AM
bozer
bozer's Avatar
Yeah if it costs about the same for the aftermarket ones, I'd just get them. Link to those?
Old 02-14-09, 10:36 AM
EyeKutr
EyeKutr's Avatar
Bozer, rominl.....what the heck are you guys talking about replacing aftermarket......dude, you said you have a crack in the mirror glass, not the outer shell right?? where is the crack exactly??
Old 02-14-09, 10:44 AM
passnu2
passnu2's Avatar
I was just thinking the same thing...its the mirror and that should be able to be replaced. I cant believe there is no replacement for that. It pops out pretty easy and I am sure many of there and not the rest get damaged.
Old 02-14-09, 10:49 AM
rominl
exclusive matchup
rominl's Avatar
oh hahhaa, ooops, my bad. somehow i just kept on thinking it's the cover that's cracked @_@ if that's the case, then there are aftermarket stuff
but if it's the mirror glass itself, then tough luck
Old 02-14-09, 12:58 PM
bozer
bozer's Avatar
Its horribly cracked but also I have a big white mark on the outside probably from some tard opening their door into my car in a parking lot.
I pretty much need to replace the whole thing I think. So if its not much more for the aftermarket with turn signals I guess I could do that too.
Old 02-14-09, 01:43 PM
passnu2
passnu2's Avatar
the turn signals are just a shell for the outer part so you can do that for less money then OEM or if you want I have my covers. The mirror you should be able to find somewhere to replace it. It does come off and I cant believe they only sell the whole mirror assembly. If that is truly the case find a wrecked GS and go take it and give them 50$ for it. Nigel is selling these mirror covers.
Old 02-14-09, 01:46 PM
dunnojack
dunnojack's Avatar
isn't there a part number on the backside of the mirror glass?
maybe you could order it.
i once had that mirror replaced on my old car. i went to a glass shop to have it custom cut.
Old 02-14-09, 02:01 PM
EyeKutr
EyeKutr's Avatar
you cant make a custom one unless you want to lose your defrost and dimming functions.....you need to take it to the dealer and get your self a new one or find one on ebay in your color and take it off and put it on....putting on a new shell is not for the beginner DIYer.....changing the mirror assembly itself is a medium DIYer....
Old 02-15-09, 09:04 AM
bozer
bozer's Avatar
Thank guys. I think I'm going to just call the dealer and find out my options. I'm fully prepared to blow $500 on this =(
Old 02-15-09, 08:04 PM
EyeKutr
EyeKutr's Avatar
Keep us posted, I suspect more like $700-800 installed....
Old 02-18-09, 07:05 AM
slk_dds
slk_dds's Avatar
Dude... you must be on CRACK when you were reading/writing the thread!!! Just kidding...
Best bet would be getting it from eBay like all CL members have mentioned, best of luck.
Old 02-18-09, 11:30 AM
ILOVEGIRLS
ILOVEGIRLS's Avatar
i have an 08 pass side mirror assembly if you need it.
Quick Reply: Cracked passenger side mirror
