Where IS the tire pressure reset button on a 2008?
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
My tire pressure warning light came on today. I checked my tires, the original ones that came with my 2008 GS350, and they were all about 31-34, so I made them all 35. The warning light still did not go off.
I read the manual about the initial reset sequence to see if that would make the warning light go off, BUT the button that the manual says to push is NOT on my car. I suspect the manual is wrong, since the button was probably moved after 2007 but the manual was not updated.
Where IS the reset button on a 2008? (I *guessing* that it might in the same place on a 2009 as well.)
If you look in the manual, there is picture taken from the driver's perspective, which shows the button in clear view while seated. Obviously, this not where it actually is. And, after putting air in the tires -- which didn't they need anyway since the lowest one was about 31 -- and driving it for a while, the warning went away, which now that I think about it happened to me once before.
Put your cell phone camera in selfie mode and lay it on the floor of the driver side under the steering wheel. You will be able to see the re-set button this way. This is how I found it.
kSunflower
CT 200h Model (2011-2017)
04-23-18 07:36 AM
Grogin13
08-11-14 06:49 AM
