Need Help Removing the Back of Seat !!!!
I'm putting in some headrest monitors and I need to remove the hard plastic seat backing, anyone know how to safely remove these, or know the right way it should be done ?
Thanks.
Thanks.
seat back cover
There should be a loose leather cover in the bottom, attached with elastic straps. Undo the straps and you will see two little screws under the bottom of the cover. Then just pull down and remove the cover. Good luck!!
mrpink13
07-18-17 01:38 PM
