Oil overfilled - Problem?
I had the local Firestone / Bridgestone dealer change the oil on my 08 GS350 today. I had transferred a lifetime alignment from another car and they do free tire rotations. They did have to adjust my rear alignment. Had discount coupons that brought the oil change down under $50. Lexus dealer wanted about $150 (w/o alignment) and is hard to get a loaner out of for the short services.
It appears that the tire dealer put 7 quarts of oil in the car. They charged for 7 and the oil level on the dip stick is almost up to the first bend in the stick. Car runs fine - as opposed to my old Q45 that ran rough when overfilled. I have a suction pump and can easily remove the 1/2 quart thru the dip stick tube. Should I do that, or is it alright as is?
Thanks in advance.
Thanks in advance.
My Lexus dealer used to charge me only $50 for a oil change, Firestone oil changes are as risky as Jiffy Lube. Over filling the oil might be the least of your problem if you keep going there.
Thanks in advance.
Thanks in advance.
i'm sorry, but we spend upwards of 40-60K on a car and look for a discount oil service or tire dealer....aren't those 2 of the most important parts of the car?????
![Agree](https://www.clublexus.com/forums/images/smilies/iamwithstupid.gif)
executive matchup
and if it is done incorrectly and you have problems later, lexus could technically say it wasn't serviced properly (and hence deny warranty claim). it's an extreme example of what can happen if something goes wrong...
Sorry to thread jack, now back to your regularly scheduled posting.
L
I'd definitely take out the extra oil. When you overfill an engine the crank can possibly hit the oil and whip it into a foam then the oil pump won't pump it. Obviously it's not THAT bad in your case but that's why everyone preaches to not overfill vehicles.
I really hate going to the Lexus dealer. When I went in for the 5,000 mile service I had to wait in the lounge for 15 minutes before they would even see me. Took the guy almost 30 minutes to write it up and get me the loaner car. FYI, getting a loaner at my local dealer is a major effort! They REALLY dont want to give them out and they service writer has to walk around back and bring one around - a 5-10 minute tak. Then I had to wait 15 minutes again before they would see me when I came back to pick the car up. I even tried to make sure to come when they were less busy (drop off at 9:00 AM and pickup at 2:00). At least that service was free. Plus apparently the Lexus dealer uses 10W-30 even though 5W-30 is recommended by Lexus (that is what they write on the window sticker).
I refuse to pay 3X the price of a tire store/quick lube for the thrill of sitting around all day. I was in & out of the Firestone much quicker.
My local Infiniti dealer knows what they are doing. They have all the loaner cars sitting out front in a row, the paperwork is already pre printed, just go in sign, get a set of keys and drive off.
executive matchup
Next time change it yourself. Just make sure that the oil filter gasket from the old filter comes out with the old filter. Easy to do and you can use the best oil and filter for your great car. A little extra oil will not hurt but you will smell it.
Thanks for the replies. I think I will order some of the Toyota filters and do the oil changes myself in the future. I do them myself on my Infiniti and Suburban (boy the Suburban is easy - dont even have to jack it up or use ramps). As for a different Lexus dealer - my local dealer is 10 miles from my house, the next closest one is 75 miles. Not really an economic option. I could use the local Toyota dealer I guess.
I did pull the extra oil out, not much, less than 1/2 quart. Better to be safe than sorry.
