Repaint Problem/Question
To make a long story short i had to get my rear bumper of my car repainted. The place i took it to is certified by Lexus and is the dealers body shop. My car is painted GFM, however when i was washing my car last night, i could easily tell a visible difference between the rear bumper and the quater panel. The rear bumper looks like a bright white color and the rest of the car looks a whitish gray. I had the bumper repainted 2 weeks ago and when i picked the car up everything did look good, i noticed a slight slight difference but i thought it was my mind playing tricks on me because i knew it was just painted, however when i went to wash it last night, i really noticed a difference even standing about 10 feet away from the car.
Even though its been 2 weeks, can i still call them and have them fix this? After last night, im really not happy with the outcome of the repaint.
i called the body shop and he was very helpful. he told me to bring it down and if it was indeed very far off, he would repaint at no cost and even pay for a rental for the 3 days they need the car.
out in the sun it was hard to really tell with the lights but under the florescent lights, it was pretty obvious.
To get this done correctly, you need to have them blend the paint while the bumper is attached. I had this issue with my front bumper several times and it took them to blend it to get it right? Regardless of the color, if they spray it off the car it will be hard to match correctly unless they blend the areas around it? The type of material your bumper is made out of will make a difference also, if it's an aftermarket bumper? Don't just settle for the respray, because over time if not done correctly, it will be off again!
To get this done correctly, you need to have them blend the paint while the bumper is attached. I had this issue with my front bumper several times and it took them to blend it to get it right? Regardless of the color, if they spray it off the car it will be hard to match correctly unless they blend the areas around it? The type of material your bumper is made out of will make a difference also, if it's an aftermarket bumper? Don't just settle for the respray, because over time if not done correctly, it will be off again!![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
You will be best off with the best color match they can do by painting only the bumper. If it is off, live with it. They are all off except the black bumpers. Look at your other bumper and will notice it doesnt match either. Take the advice of a former painter, dont disturb any more than necessary especially when matching the bumper.
Take it back and have it repainted!!!
Similar had happened to me also when my toy was only 2 weeks old, some moron "hit&ran" into my front bumper in the parking lot.
My dealer had it repinted (without blending with fenders) did a perfect job, except some fxxkup left a thumb print on it.
So they had to send it down and repaint it again, still job done perfect!!!
I agree that you shouldn't disturb any more than needed to do a color match, but in this case painting the 1/4 panels is necessary, especially since the color is a tri stage. Come on, the basic rule of painting a new part is to blend all adjacent panels, especially on a tri coat color.
BTW, even the black bumpers are off in color. This is advice coming from a current painter.
my 2IS was GFM. It took the experienced painter to do about 15 test panels IIRC. 15 Test shots of this tricky 3 stage paint to get it perfect. Of course by the time i picked up my car, it was perfect! Matched exactly. Blending was not needed.
you have to consider, even if the paint mix is dead on.. but the painter is not experienced, laying on the paint too thin or too thick will affect the overall outcome.. That's why people have to pay a premium for 3 stage paint.
