Need help, quick question on rim fitment
if you are tucked now with stock wheels, then with 19s they will
keep in mind one thing. you are getting larger size rims, but at the same time you are getting lower profile tires, so your overall diameters are pretty much the same as your stock setup up. it's not like if you get larger rims your car will be "higher"
Hello!
Looks like somebody had the same plans as I do now. What did you end up getting? I would like to get the same 19 inch wheels with offset 35 . What are your new tire sizes? Got any pics of the new setup?
Thanks
Thanks
