Need help, quick question on rim fitment
Old 03-31-09, 03:39 PM
maying856
maying856's Avatar
Lightbulb Need help, quick question on rim fitment
I am planning on purchasing a set of wheels in the upcoming weeks, but I would to get some feedback from this forum before I shell out the money for it. I am no expert on wheel and tire fitments so any help would be greatly appreciated. The specs are as follows:
Rims
Front: 19x8.5 35 offset
Rear: 19x9.5 35 offset
Tires
Front: 215-35-19 or 225-35-19
Rear: 215-35-19 or 225-35-19
Will these fit properly and will I have any problems with rubbing etc. at my current ride height? I would like to stay at my current ride height, and I was considering shaving or rolling the fenders if necessary. Thanks!
Old 03-31-09, 03:58 PM
passnu2
passnu2's Avatar
what are the offsets
Old 03-31-09, 04:02 PM
maying856
maying856's Avatar
Sorry, the offsets are 35
Old 03-31-09, 04:28 PM
rominl
exclusive matchup
rominl's Avatar
you want to run those tires? they stretch quite a bit.
this is what i think. your offsets aren't that aggressive at all, with those tires (stretched) you don't have to touch the fenders, and it looks kind of weird. people run stretch tires mainly because the offsets are aggressive and even rolling/shaving fenders aren't enough to clear
my 2 cents
Old 03-31-09, 04:44 PM
maying856
maying856's Avatar
my 2 cents
So should I get 215, or 225, 245? What kind of tire do you think I should run for the fronts and rears................? Im such a noob at this
Old 03-31-09, 04:58 PM
spine911
spine911's Avatar
For 8.5 x 19 wheels, i'd definitely go for 245 width tires.
215/225 are would look better on 7.5 width wheels
Old 03-31-09, 05:48 PM
spine911
spine911's Avatar
215/225 would look better on 7.5 width wheels
IMO, your car with the slammed stock 18s look great...the tucked in effect gave it the "punch"...i wouldnt even bother with 19s
Old 03-31-09, 07:10 PM
passnu2
passnu2's Avatar
Do you want to be tucked? or do you want to be flush with the fenders (assuming you trim the rears)....
Really boils down to this. I dont care for stretched tires. I should have my set up in ~ 1 month. Tires I have in my garage are 255/30-20 & 295/25-30....just waiting on the rims to come in. I will post pics once I have them on.
Old 03-31-09, 09:48 PM
maying856
maying856's Avatar
I would rather have it tucked, so I dont have to worry too much about the tire making contact with the fender. Should I just go with 18" wheels then instead of 19's?
Old 03-31-09, 11:52 PM
rominl
exclusive matchup
rominl's Avatar
don't go 18s, if so might as well just stick with stock wheels
on the tires, it really depends on what you want. how aggressive do you want to go? fender mods? and if so, are you willing to stretch tires to get more aggressive offsets? they are all questions you should decide for yourself. you shouldn't stretch tires just to
Old 04-01-09, 06:54 AM
maying856
maying856's Avatar
Well I really just wanna stick as close to stock as possible without having modify my fenders or worry about rubbing, but still be able to go with a 19" wheel. A 245/35/19 tire would be closest to stock correct?
Old 04-01-09, 08:44 AM
spine911
spine911's Avatar
OK let's hold on here for a while (before we go fender modding, stretching tires..etc...etc). As per your initial Rims/Tires spec.
Rims
Tires
I noticed that youi have a stagerred wheel setup. IMO, going same tire sizes on all 4s would not look right.
Yes, you are ok with the front of 245/35/19. (245/35/19 is ideal for an 8.5 wheel width)
You have to go wider on the rears. 255 at least, BUT with a profile ratio of 30s.
Old 04-01-09, 10:06 AM
maying856
maying856's Avatar
Rims
Tires
How about 235/35 front, and 245/35 rear? 255/30 seems a little too wide.........
Old 04-01-09, 10:23 AM
rominl
exclusive matchup
rominl's Avatar
ok, if you don't want any fender mods at all
19x8.5 +35
19x9.5 +35
they should be ok. i would put 245/35 and 275/30 tires
if possible, i would likely prefer
19x9 +38
19x10 +43
with the same tire spec i had above
Old 04-01-09, 11:40 AM
maying856
maying856's Avatar
19x8.5 +35
19x9.5 +35
19x9 +38
19x10 +43
Thanks for the response
Ok, I think im getting the hang of these wheel sizes etc. Thanks for all your responses so far! So will my wheels still be tucked at 245/35 and 275/30?
I apologize for the endless questions, I just wanna get a grip on this and make a wise investment
Quick Reply: Need help, quick question on rim fitment
