Was the install difficult? was just measure, cut and stick. Or did you remove the panel?
The hardest part is removing the trim. You have to get the Xmas tree clips off that hold the trim on....it's very hard not to break them. Then you have to take the chrome trim piece off. Then you wrap the material with some heat and go around the curves carefully. It's very labor intensive.....but worth the hastle.
