help, how to install dvd player
Old 04-21-09, 03:06 PM
egydude15
egydude15's Avatar
Default help, how to install dvd player
ok guys im new to this forum but im not new to working on cars, in many cars i have installed indash dvd players, universal dvd players, sound systems and all that good stuff, this is the first time im going to work on a newer lexus, i bought the NAVTOOL so i can add a dvd player to my car, the navtool installation is very simple, but the universal dvd player is the one that im wondering what to do with, usually in other cars (honda, mitsu, acura etc..) i can splice into the harness to get the acc,12volt, and ground but most of the cars i do already have aftermarket headunits so i just put in those connections with the after market harness, this car is very nice and expensive and i dont want to just splice into wires and stuff, what do you guys recommend in order to connect the wires to get the dvd to operate (the power wire, ground, acc, and any other wire im missing to mention) thanks guys, let me know
Old 04-21-09, 04:30 PM
maxtcee
maxtcee's Avatar
i just installed mine and i also have the vais sls and right on one of the clips theres a red wire that give power when you hit acc all i did was shove it in there with a test light and ran the wire to the glove box works now prob
Old 04-21-09, 05:27 PM
egydude15
egydude15's Avatar
ok, i know the ground is the easy one to put in, then i hav the acc and 12 volt wires, dont i need 2 connect each of them to a separte terminal? which 2 did you connect ur wires to?
Old 04-21-09, 06:54 PM
egydude15
egydude15's Avatar
bump, help anyone?
Old 04-21-09, 10:37 PM
joeker
joeker's Avatar
i would also like to know.. i'm planning to install a JL cleansweep and i was considering tapping into the factory amp harness and soldering into the +12V, power switched, and ground. if there is another way of doing this i would like to know how..
Old 04-22-09, 04:55 PM
maxtcee
maxtcee's Avatar
Originally Posted by egydude15
bump, help anyone?
i tapped into my vais sls there a clip with a red wire and one with red with white stripe the red was acc and the red with white stripe was 12v those are the wires i used i just pinned it in with the point from a test light try and and get a test light and you will be able to find the wires you need if your not using vais you might want to look at the 12pin connector use any of the wires from the head unit so long it gives power with acc and then find the wire that gives 12v might
Old 04-22-09, 05:02 PM
maxtcee
maxtcee's Avatar
i never tried this but i wouldnt splice any wires i would just try tapping into the clip in the rear trunk where the factory amp is theres got to be a 12v wire in the clip
Old 04-22-09, 07:39 PM
egydude15
egydude15's Avatar
bump, anyway to get power from the fuse box? i know they sell something called add a circuit or something like that, would that work?
Old 04-23-09, 08:29 AM
THE.K.W.C
THE.K.W.C's Avatar
I thought you said you were use to working on cars..... go out buy a multi meter and test for a 12v constant behind the deck or at the fuse box as long as its more then 10amps you will be fine, then test for a acc wire by turning on and off the Ign
Uchka
LX - 3rd Gen (2008-2021)
10-27-12 09:59 PM
Landbert
RX - 3rd Gen (2010-2015)
07-06-12 06:43 PM
brattygirl
IS F (2008-2014)
46
04-18-09 09:13 AM
sao1
12-07-06 06:02 PM
LX470NY
17
05-31-05 06:19 PM
Quick Reply: help, how to install dvd player
