Different Brakes Between AWD & RWD?!
Old 04-23-09, 10:12 AM
Yang1815
Yang1815's Avatar
Exclamation Different Brakes Between AWD & RWD?!
So I was looking into getting drilled/slotted rotors for my 07 AWD. Turns out there is no part/pricing available from Jay (vendor) for front rotors. Is this correct?! I've always thought the brakes are the same and therefore swappable between the AWD & RWD 3GS... Thanks.
Old 04-23-09, 10:20 AM
rominl
exclusive matchup
rominl's Avatar
that's my impression too, i never heard that brakes are different on awd
Old 04-23-09, 10:22 AM
Yang1815
Yang1815's Avatar
One thing I remembered was that there's a size difference between V6 and V8 for MY08+ is that correct?
Jay just called Stop Tech and told me that Stop Tech said the brakes are different between AWD and RWD...
Old 04-23-09, 11:13 AM
rominl
exclusive matchup
rominl's Avatar
no, 07+ gs350 (rwd) and gs430/450/460 all have the same brakes. the pads might be different
interesting info from stoptech. i wonder what is different
Old 04-23-09, 11:16 AM
Yang1815
Yang1815's Avatar
So it's the MY06 V6 that has smaller brakes?
As for the difference, I'm not sure.
You replaced the whole set-up right? I can't think of anyone else who's replaced their brakes on top of my head...
Old 04-23-09, 01:57 PM
Stormforge
executive matchup
Stormforge's Avatar
are you doing a bbk or oem size aftermarket brakes?
Old 04-23-09, 02:25 PM
Yang1815
Yang1815's Avatar
I'm looking for OEM size.
Drilled/slotted rotors to replace the stock ones.
Old 04-23-09, 03:48 PM
rominl
exclusive matchup
rominl's Avatar
yes, 06 gs300 is the ONLY 3gs with small brakes
yeah i replaced my whole stock brakes with bbk. i know a few others who have bbk too
Old 04-23-09, 04:37 PM
Stormforge
executive matchup
Stormforge's Avatar
did you check with your lexus parts dept to see if the front oem rotor for your awd is the same part # as the front oem rotor for the rwd? if it's the same part number, then you know that the same rotor is used, and can be confident to use aftermarket front rotors for rwd application for your awd.
Old 04-23-09, 07:07 PM
LexFather
Guest
Posts: n/a
Correct GS 300 is the only one with 2 piston front brakes. Every other GS has the big 4 piston front brakes.
To my knowledge all rears are the same.
Old 04-23-09, 09:18 PM
Yang1815
Yang1815's Avatar
Good point. I'll check then. Thanks!
No other AWD owners care about aftermarket rotors?!
Old 04-23-09, 09:21 PM
Stormforge
executive matchup
Stormforge's Avatar
you're probably the first awd gs doing this mod. let us know how it turns out. good luck!
Old 04-23-09, 10:49 PM
krava
krava's Avatar
Default brakes
don't really use brakes much. put 49K on a corvette that had been upgraded and never had to change them. the only time I ever had to change brakes is when I left the emergency brake on going 35 mph down the highway for awhile
Old 04-24-09, 04:31 AM
lextronics
lextronics's Avatar
I have aftermarket rotors on my awd 06' gs300...they fit fine, no problems...
Old 04-24-09, 07:38 AM
Yang1815
Yang1815's Avatar
Thanks. I assume all 4? It's too bad that the 06 brakes are different from mine...
Quick Reply: Different Brakes Between AWD & RWD?!
