i believe deactivating the drl must be done by the dealer (not 100% sure tho)
This is correct. I got mine de-activated by the dealer as I think it's useless. They told me they can't de-activate the seatbelt chime though as some mentioned on here that it could. I tried the sticky, but it didn't work. I think the instructions don't work for the '08. Anyone know about that?
if you play with the bulbs they will probably hold it against you. I thought that bulbs and lamps were considered wear and tear like brakes and tires. I am wondering if you might be on your own on this one. Be nice to your service rep when you take it in
Perhaps the bulbs themselves are...but melting of the area surroundings of the bulb is definitely a design flaw which they should cover and give complementary replacement bulbs at the very least.
i could understand that if his bulb burnt out but it melted the housing also. a stock bulb would not get that hot to melt the housing.
