Got my 20" on. Please opinion......something is missing..
#46
executive matchup
you need to know your offset, wheel size, and tire size before you do anything. this info would tell us if you would rub if you were lowered, and how much room to play with if you want to add spacers. without this info, everything would be speculation.
#47
What size are your tires? There should be a number on them like 245, 255 etc. They should be 245 or 255. If your wheels are 8.5" wide, you should be fine with 10mm spacers or anything smaller.
I was able to use 8mm spacers without having to replace my lug nuts/bolts. The shop who installs them has to be able to tighten the lug nuts to a certain degree, and I would say with 10mm or bigger you will probably need new lug nuts. If you can find a local shop that does this sort of thing, they should be able to order the spacers for you.
#48
Tire size has little to do with the spacer required. What we really need is the confirmed width and more important, the offsets. Any spacer you use should be a hubcentric spacer with it's own studs so there is no issues with the factor studs.
Also, is your car an AWD? If so, I would not suggest using a spacer since that would change the geometry of the wheel track, which may cause issues down the road.
#49
Tire width, which is what I referred to, will come into play with rubbing issues. Using a spacer on an AWD vehicle should not cause any issues at all.
#51
He got me some weird numbers. Inside the wheels has the numbers 8.5x20, tire sizes are 245 35 ZR 20 ALL AROUND. Other numbers are c19 A17, and 11312805, there is also H6/2/03. I am not sure if these make any sense.
#57
typically on wheels on the back side of one of the spokes is a number that is usually +XX (XX refering to whatever the number may be). That is the offset of the wheel. if you dont know the offset, you can always call the manufacturer and they should be able to tell you.
i tried looking thru the thread but i couldnt find any info on the wheels you have. let me know the name and style of the wheel and ill try to look up the offset for you.
#58
Ok, called the guy he said +38. Also, he said adapters are not a good idea they will have issues on lexus. He said spacers, whether 5, 10 are Ok, and he told me about a store that sells them locally and install them. So does this help at all?
#59
yea 38 is a pretty common offset.
as far as using spacers i dont know. i know staggered isnt idea with wheels on AWD because you get more surface contact in the rear. With spacers though, you still have the same amount of surface contact except the rear wheels are pushed out a bit farther. Not sure if that does actually mess up the AWD or not. I wouldnt think so but maybe Mark knows a little more about this.
