GS350 Clatter Noise Upon Engine Start
#61
,,,,,i had this exact same problem with a new Toyota pick up....at first dealer shined me on but I persisted....they pulled engine and replaced short block under warranty....problem solved....JB
#64
Sorry to bump the old thread.. however I just took my car in for the same issue ..
According to the service rep noise is coming from the camshaft... hope it gets fixed!!
#65
Of course I started getting this problem after my powertrain warranty had lapsed. So does anyone know exactly what the problem is and what the corrective action is? I wonder how much it would cost to fix without warranty...
#66
I'd like to know this too. Noise began at 75k.
#68
If you got your recall work done, you should have received an extended warranty for your powertrain (100,000 mi?).
This should be covered under that shouldnt it??
Hope you guys get this resolved. They redid my camshafts when they had the engine apart to do the recall. Havent heard the noise since that.
Somewhat maddening that this happened at all. Good luck guys.
#70
Just got my car back from the dealer.. let me look into my invoice and see what work/part was changed/performed... FYI, I got the work done through the warranty so I won't know the cost.. Good luck!!
#71
If you peeped through the invoice the one you signed but couldn't keep, you would see how much they billed Lexus.
#72
Sorry it took a while.. i completly forgot
Im just typing out what was on the invoice..
Camshaft, Engine - LOUD Rattling Sound cabe be heard form engine compartment during initial start up..
Cause: Oil leak down from both intake cam gears En10 camshaft, Engine -
Gear Assy, Camshaft
Gasket
Gasket, Timing Chain
Camshaft Bea
Gasket
Insulator Fuel Pump
Gasket Cylinder Head
Gasket, Air suge TA
Oil Leak down from both intake cam gears EG7027 replaced both inatke cam gear assemblies with updated cam gears as per TSIB L-SB-0157-08.
Preliminary Estimate $2396.36
hope this helps!
Gear Assy, Camshaft
Gasket
Camshaft Bea
Gasket
Insulator Fuel Pump
Gasket, Air suge TA
hope this helps!
