Can anyone tell me what these are?
exclusive matchup
^nope. my varianza T1S and the SC1 are both hub centric (no rings). You order them that way from Work. All rims from Work you can get the hub to your size. You have to tell them you want a different size hub for them to be larger. Where its more common to find Work rims with larger diameter hub is if they are off the shelf so they are universal. If you custom order them they will fit like a glove
Volk doesnt offer this I just recently found out and more common with jdm wheels as you mentioned. You have to use hub rings with their rims but much easier to sell them like that. Work is the first set of rims I have not had to use hub rings. But I never had any problems in the past with other make wheels and hub rings.
Both my sets where made for Lexus hubs 60.1. Down fall is they are only good for a few makes so may be harder to sell down the road.
about the hub, yeah, 60.06 and 60.1 doesn't really make that much difference. 0.04mm that is!
executive matchup
Pics are coming guys, just need to install everything first
Yup, they knew its for a GS. Its even says on the box, "GS430/350 only for the use of Lexus with tire pressure sensors". I'm just not sure why the hub rings were included?
Anyways, even if I dont put the hub rings, what's the worst that could happen? Vibrations ?
just test fit them real quick and it will tell you if they are hubcentric already. the wheels arnet on your car so flip a wheel over and try to put a hub ring in on the back side. if it fits then the wheels are not hubcentric.
problems for not using them are mainly vibrations while driving. also it puts all the weight on your studs as opposed to your hub. having the weight on your studs can possibly shear off your studs. its rare but it does happen.
executive matchup
you should confirm with the vendor that you dealt with whether or not the hub rings are needed. they would know for sure.
executive matchup
