wheel stud broke and need help....
has anyone have to replace there wheel stud before if so is there any pictures to show me how to replace mine? i have broke my wheel stud from screwin it to tight.. i think the last place i went to get my tire rotate and they over tighten it.
thanks guy for your help...
It's very easy to do, if you can get a air tool will be easier to install, to take it out, just hammer it out and insert the new one in from behind, then without installing the wheel, use a regular nut to pull it right thru the splines all the way out using the air gun. then unscrew the nut and install the tire with the regular wheel nuts.
They broke the stud on my G35 and they were going to replace it at some mom and pop shop. I insisted that it would be replaced at the dealership. They took care of it easily. Its anoying but can be a fact of life when mounting and unmounting the wheels
EddierRo
04-01-09 07:17 PM
curt248
10-02-08 10:06 PM
chubby
CL of Southern California
07-19-07 01:30 AM
