Vaistech SlVi2 Install Suggestions
so i bought the vaistech ipod video integration kit and now i was wondering where i should install it?? any suggestions with pictures???
i saw one post where the person placed it in the center console. that seems like it is the best option but i wanted to see if anyone else had another suggestion that might be better.
Yea, I installed in glove compartment.
Side question, is there supposed to be an adapter or something to have the iPod charge? Mine doesn't charge using the regular adapter...
There should be another piece that the adapter connects to, which then connects to the iPhone or iPod for charging capability. I don't have any photos, but it would've come with the box. Was mentioned that all new versions of the SL2Vi will have the charger adapter.
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
i'm trying to install the vaistech right now, but one of the plugs wont' fit into the factory harness... did you guys have to dremel off a portion of the factory harness plug??
updated: called vaistech.. apparently you have to sand it off. hopefully the rest of the install won't be too bad.. btw...that little black thing in the center console is freakin hard to take off
it was the blue plug that goes from the bottom of the head unit to the top. i think there are 6 pins inside of it.. there is this little plastic thing on the bottom of it that i had to shave off..
and the black thing is that cover in the center console that is stuck on there like no other.. supposedly it is just stuck on there with some kind of tape or foam thing.. but i think mine is super glued or something.. haha.. i had to give up and just installed the ipod cable in a different location..
and i know which panel you talking about. it's indeed "taped" up pretty well (the whole bottom). if you want, get a little tiny l bracket as leverage and it will come right up
98023IS250
11-22-09 08:53 AM
engin_ear
12-31-06 08:44 PM
BottomsUp
09-21-06 09:06 PM
