3GS wheel thread
Old 11-19-15, 10:39 AM
  #1756
Mesca
Mesca's Avatar
Originally Posted by ksan
I was rubbing on m 235/35 on a 20x10 +15 up front... It wasn't rubbing for the first 2 months of having my wheels on then all of a sudden i started to rub on full lock turns. So i was told on my next setup to go with a 245/30 for my 20x10 +25... I like more meat on my tires due to living in MA.. any input? I didn't roll my fenders..
Your front is such an aggressive size that it may be something you have to live with. 245/30 is a thinner tire but its 10mm wider so depending on HOW you rub it may not get rid of it. However 245/30 is less likely to rub and that just might be the right tire size for you.
Originally Posted by pschmoneyy
I'm running 20x8.5 all around you think 235/35 will rub? PA streets are rough man potholes everywhere I want to run the meatiest tires I can without any rubbing or modifications. Can someone answer my question as to how 255/30 are meatier than 245/30?
The higher the first number the wider it is. The second number is a percentage of the first number on how thick the tire is. 255/30 is bigger than 245/30, so your assumption is incorrect that bigger number is smaller. 245/35/20 is over 3% bigger than stock(that's not good for the drivetrain) and a lot of people are getting rubbing issues with that size. So since you said you want the meatiest tire without rubbing, 235/35/20 is a great choice.
Old 11-21-15, 11:42 AM
  #1757
tatumjonj
tatumjonj's Avatar
I'm thinking of going with 235/35/19 on a 19x8.5 +35 front and 265/30/19 on a 19x9.5 +35 rear. This is a 2006 GS300 RWD. I shouldn't have any fitment problems with that right? Thanks in advance.
Old 11-22-15, 10:45 PM
  #1758
Mesca
Mesca's Avatar
That is a good set-up, you should be okay!
Old 11-23-15, 05:36 AM
  #1759
tatumjonj
tatumjonj's Avatar
thanks I think I'm going to go ahead with it.
Old 11-23-15, 07:54 AM
  #1760
VIPking
VIPking's Avatar
Here is my latest setup 19x10 and 19x11
18" Gewalt Wheels step lipped to 19"
Old 11-23-15, 07:57 AM
  #1761
VIPking
VIPking's Avatar
Need smaller tires to go a tad bit lower running 225 40 up front and 225 45 in rear.
Old 11-23-15, 11:33 AM
  #1762
VDMTom
VDMTom's Avatar
Just got these newly released WORK Wheels T7R 2P on my car last week..
Sizing 19x10 & 19x11 w/ 235 & 265 tires.
Old 11-26-15, 12:13 PM
  #1763
nicestiman
nicestiman's Avatar
Happy Thanksgiving everyone! 19x10 19x11
Old 11-30-15, 07:07 PM
  #1764
tatumjonj
tatumjonj's Avatar
Thanks so much everybody for all your help. What started as a brake job ended up as this thanks to the enablers on this forum.
Old 12-02-15, 01:32 PM
  #1765
gorgeous
gorgeous's Avatar
Default Gorgeous is done!
Fosgate 12" with box and custom divider
custom Aero Kit by LaziDucks<br/>
Aerokit by LaziDucks
20x9 & 20x10 Rohana RC10<br/>Satin Blue wrap with glossy blk trims
hanifh (09-13-22)
Old 12-04-15, 06:56 AM
  #1766
LexusLive
LexusLive's Avatar
Default Question: Can I put 245/50R18 Pirelli Cinturatos on my 2006 GS 300 awd?
I'm running size 245/40ZR -18 right now. But I really want a little more sidewall. 18" rims are tiny compared to what you guys use, so I'm hoping I can get away with that slightly larger diameter! Thanks.
Here's a link to the Pirelli Cinturatos:
http://www.tirerack.com/tires/tires....7ASP&tab=Specs
Old 12-06-15, 06:50 PM
  #1767
Believer39
Believer39's Avatar
Default Stripped/broken wheel stud
Anyone know dealer pricing to fix a stripped/broken wheel stud on a 07' GS?
Old 12-10-15, 10:02 PM
  #1768
858racer
858racer's Avatar
Need help from you wheel experts! I just purchased a set of wheels for my 3gs and am now looking for tires. Wheel size is 20x8.5 +30..20x10.0+36. I will be installing coilovers on the car and plan on slamming it. I was thinking of purchasing 225/30/20 for the fronts and 255/30/20 for the rear, any thoughts on this setup? Also, I'm pretty sure the rear fenders need to be shaved? Any help will be greatly appreciated!
Old 12-12-15, 12:30 AM
  #1769
Mesca
Mesca's Avatar
If you plan on slamming it then you might need all the clearance you can get, and those tire sizes will do the trick. I personally think that front tire would be like a rubberband and you risk cracking or bending a wheel. Imo, I would 225/35/20 and 255/30/20 but I'm lowered to no gap, can still see all of the tire. Rear fenders you can shave, fronts are better rolled.
Old 12-13-15, 08:58 PM
  #1770
masboy
masboy's Avatar
DIY on youtube. Or any independent shop can do it. Dont go to stealership pls.
Quick Reply: 3GS wheel thread
