3GS wheel thread
Old 03-11-16, 04:25 PM
  #1816
msgs350
msgs350's Avatar
Originally Posted by jrm7885
How's it going? Need some opinions on my wheel set up. I'm picking up a low mileage 430 and I'm going to be running a set of wheels off of my 00 Ls. F-20.9 + 35 R 20.10.5 +35. Tires are 245/35 & 275/30. Will I have any problems with running h&r springs? Oh, and I'm running a concave wheel. Any info would be great. Thanks.
I think front will rub due to 245/35 and rears will clear, if you shave your fenders. You may be able to roll the rear but due to the design, it may dimple.
Old 03-12-16, 04:56 AM
  #1817
ADI$A69
ADI$A69's Avatar
I run a 20x9 245/35 offset 32, no rubbing on my 07. I'm on stock suspension though, not dropped yet
Old 03-14-16, 05:50 AM
  #1818
grayson73
grayson73's Avatar
For AWD, stock suspension, and no drop, Allen Alvarez from Vossen told me:
"You would run 20x9 ET 38 with 245/35/20 and 20x10.5 ET45 with 275/30/20 with no issues. Plug and play fitment. "
He also said that if I wanted 19", it would be 19x8.5 ET32 and 19x10 ET38.
Would 19" or 20" look better on AWD with no drop?
Old 03-14-16, 08:16 AM
  #1819
Skylar978
Skylar978's Avatar
That is preference, but with zero ride height change- I prefer 20's. I have a rule of thumb for my own personal taste though- I never throw on wheels at all unless I lower the car. Nothing is worse to me than wheel gap when you have a nice set of wheels on any car.. Probably not everyones cup of tea to lower their vehicle, but I like it!
Old 03-14-16, 11:28 AM
  #1820
grayson73
grayson73's Avatar
One thing I find strange is that Vossen recommended 245/35/20, but that's 6.7% larger circumference than stock (225/50/17). Isn't that too much difference for AWD?
Old 03-14-16, 12:30 PM
  #1821
DanilleH
DanilleH's Avatar
Default Wheels manufacturer? and suspension manufacturer?
I like your setup
Who is the Wheels manufacturer? and suspension manufacturer?
Originally Posted by jtrue28
Anybody have any idea what wheels these may be? They were in the Japanese wheel thread from a while back. I believe these are the same...just different angles. Thanks in advance.
hanifh (09-13-22)
Old 03-14-16, 03:08 PM
  #1822
eeleat
eeleat's Avatar
Originally Posted by DanilleH
I like your setup
Those wheels r called Venerdi-zwinger. I like them and tried to find them new but they don't make them anymore so I ended up getting TSW Brooklands. Similar but not the same.
Old 03-15-16, 11:23 AM
  #1823
DanilleH
DanilleH's Avatar
Default Suspension? brand and height? spacers?
Old 03-15-16, 12:27 PM
  #1824
grayson73
grayson73's Avatar
1. Looks like I'll have to go with 19" since there don't seem to be any all-season tires in 20" size (225/35/20, 235/35/20, 265/30/20, 275/30/20). Sadly, people are saying 20" would look better than 19" with stock AWD height. I'd consider lowering, but.....
2. Read a lot about AWD wobbles and vibration when lowering via springs and coilovers, so I guess I'm stuck with stock AWD suspension.
What would you do if you were in my shoes?
Old 03-15-16, 12:59 PM
  #1825
eeleat
eeleat's Avatar
Venerdi-zwinger is the brand of wheels. don't know about the rest. That's an old picture from Japan. You can tell its a right hand driver.
Old 03-17-16, 11:36 AM
  #1826
grayson73
grayson73's Avatar
The wheel gap won't change from stock though, since the wheel height is the same, right? It's just bigger rim and thinner tire?
Old 03-17-16, 11:49 AM
  #1827
grayson73
grayson73's Avatar
I think I will try 245/35/20-9 +38 and 285/30/20-10.5 +45 on stock AWD with no drop. Should be ok, right?
Old 03-18-16, 05:54 PM
  #1828
eeleat
eeleat's Avatar
235/30/20 front and 285/25/20 rear would both have 25.6" diameter for your AWD best results.
Go to tiresize.com/comparison and you can play with different tire sizes
Old 03-19-16, 07:16 PM
  #1829
grayson73
grayson73's Avatar
Thanks. Unfortunately, there are a lot of potholes here, so 25 profile probably won't work. Also, I was looking for all-season tires and there don't seem to be any in size 235/30/20.
It would be horrible if I had to keep replacing rims due to potholes.
Old 03-21-16, 12:58 PM
  #1830
grayson73
grayson73's Avatar
Are you AWD? Any rubbing on full turns?
Quick Reply: 3GS wheel thread
