Hey guys, just added the 4th gen GS F sport staggered wheels on my 3GS 450h, I noticed the offset for the rear is 60, and mine is 45, is that a big concern?
Found a local-ish deal on a set of wheels, 18x9.5 +38
My main concern is too much poke and caliper clearance. Any input appreciated before I drive 1.5 hours to test fit them.
I don’t mind running a small spacer up front to clear the brakes if needed but I’m going for a flush look with the fenders.
Looking to replace my tires and need some help on keeping the circumference/overall diameter as close as possible. 06 gs300 AWD. Rims are 20x8.5 +32 245/35/20 and 20x10.5
+32 275/35/20. Im looking to sit flush. 3gs on bc coilovers. Was looking into 225/35 and 265/30. Says circum. Is +.04% off with this setup. Anything better. Was looking to stretch the rears a little more with many a 255/30 but can't find matching fronts in 215/35. Any help would be greatly appreciated . Looking to purchase asap. Which one of these setups will work best?
Reason: Adding a pic
I ended up with slightly mismatched front and rears. I started with a used set of front's that were all I can find to match the rear's, but after a bad flat I had to switch both front's out to a new set.
There are no spacers, though I wish I would have added some...just didn't feel like doing new studs and going through it all after the wheels were already on. There was a slight rubbing up front right on the wheel well liner, so I just took a heat gun and pressed the spot in a little. Haven't barely noticed any rubbing since if any at all.
Perfect fit for the car and really looks like factory wheels. The polished face and two tone looks incredible on the Mercury Metallic. Unfortunately, I'm actually selling the car now but I can't list it here yet until I've surpassed my new member status...
Aodhan DS01 19x9.5 +15 front, 245/35r19 and 19x10.5+22 rear 273/30r19 Rainy Day shots
did you just roll the rears or shave them? Assuming the fronts are stock. Im looking at getting some 19x9.5 +22 and 19x10.5 +22 for my GS460, I ran 19x9.5 +24 squared on my GS350 AWD and had to roll the rears.
I rolled the front, and shaved the rears. You cannot roll the rears on these cars as it can warp the quarter panel. I also had to install rear camber arms in the rear. I kept those wheels for about 3 weeks before I realized I wanted to back to 20's lol.
Here is my new set up, 305 forged 20x9+20 front on Pirelli P Zero 245/30r20 and rear is 20x10.5+25 with Pirelli P Zero 275/30r20.
