3GS wheel thread
Old 02-21-22, 06:58 PM
  #2191
hunterhill
hunterhill's Avatar
Originally Posted by Oceans13
Does anyone ride 21" wheels? Im not crazy about the diameter but really like an oem design that only comes in 21x9.5". Tires would be 275/30/21. +/- 10 mm width
I've seen 22's on the 3GS before.
Old 03-18-22, 06:58 AM
  #2192
Oceans13
Oceans13's Avatar
Anybody running the 350z 19"s?
Old 03-19-22, 09:44 AM
  #2193
GSJDM
GSJDM's Avatar
Default Fitment Advice Please
Hey guys, can you please tell me if these wheels will fit on my completely stock car? I do not want to do any suspension or fender modifications at this moment.
Front: 19x9 45 offset
Rear: 19x9.5 52 offset
Probably wanting to run 245 35 19 all around if possible. Thanks in advance for your help!
Old 03-21-22, 07:25 PM
  #2194
RipCityLS
RipCityLS's Avatar
The answer is maybe.
Your rim diameter and widths are OK and the offsets are in line.
Here is the potential interference area: The caliper.
Therefore, you need to understand the profile of the wheel spokes from the hub to the caliper. If you are going for that concave look, interference with the caliper is more likely.
Old 03-21-22, 09:15 PM
  #2195
GSJDM
GSJDM's Avatar
Thanks for the reply! The wheels in question are OZ racing Leggera HLTs. They are not concave, the spokes are relatively flat. If the wheels do end up interfering with the callipers, would a spacer solve this issue? Would adding spacers cause interference with the fenders?
Old 03-22-22, 04:08 AM
  #2196
RipCityLS
RipCityLS's Avatar
Those are nice wheels!
It looks like you should be OK without spacers, but that is an educated guess. I can't tell you for sure.
FWIW, I recently bought 18x9.5 Rosenstein Delta wheels, which have a similar 5-spoke design and they clear the calipers.
Old 03-22-22, 07:14 AM
  #2197
RipCityLS
RipCityLS's Avatar
Another thing. You may be real close with the spindle on the front. My 18x9.5 wheels with a +38 offset clears the spindle by only about 3/16"-1/4". Your taller diameter wheels should help because there is a little extra clearance. This is because the spindle is moving away from the wheel as wheel diameter increases. It's possible a 3-5mm spacer will be necessary, which may also require you to get longer wheel studs.
Old 03-22-22, 09:04 AM
  #2198
GSJDM
GSJDM's Avatar
Oh ok I see thanks! Do you think the extra width will interfere with the fenders if I use spacers? Or is this not a concern on suspension? Will the rear be ok? According to this offset app I'm using, it goes much deeper into the wheel well compared to stock.
Old 03-22-22, 09:33 AM
  #2199
RipCityLS
RipCityLS's Avatar
The rear will fit. No brainer. What is the app?
Old 03-22-22, 10:53 AM
  #2200
M15U
M15U's Avatar
Does anyone know if 255/35/19 SQUARE will fit on 19x8.5 +33 on stock suspension without rubbing or poking out too much? It's a 2007 GS450H RWD.
Old 03-22-22, 11:55 AM
  #2201
GSJDM
GSJDM's Avatar
Thats good to hear!
The app is called: Tire size calculator
Old 06-20-22, 01:58 PM
  #2202
gs350bry
1st Gear
gs350bry's Avatar
2011 GS350 RWD
Vossen HF-5
20x8.5 +38 front (custom ordered sizing, took about 2 weeks)
20x9.5 +45 rear (custom ordered sizing, took about 2 weeks)
235/35-ZR20 Michelin Pilot Sport 4s front
275/30-ZR20 Michelin Pilot Sport 4s rear
Yellow Speed Racing coilovers
Manzo adjustable front upper control arms
SPC Performance adjustable rear camber arms
No rubbing.
The following 4 users liked this post by gs350bry:
Boomin (06-20-22), doitup (09-04-22), petershen (09-02-22), RSJSC400 (08-25-22)
Old 06-20-22, 04:53 PM
  #2203
Boomin
Boomin's Avatar
Originally Posted by gs350bry
2011 GS350 RWD
Vossen HF-5
No rubbing.
Wish we had a love tab!
gs350bry (06-20-22)
Old 08-23-22, 04:12 PM
  #2204
Layzee888
1st Gear
Layzee888's Avatar
Default Omfg! I screwed up my wheels!
So today I decided to use Meguiar’s Hot Rims Wheel & Tire Cleaner (the pink liquid bottle) to clean my wheels and tires. The bottle actually says specifically for OEM clear coated factory wheels.
I guess I thought my wheels were, but I done screwed myself over! Now they look horrendous. Most likely have to get my wheels repainted at a body shop. Any tips?
Old 08-23-22, 04:41 PM
  #2205
MX73
MX73's Avatar
Yep, they will need to get refinished. A wheel shop can do this and fix your curb rash for the same price. A body shop, maybe.
Layzee888 (08-23-22)
Quick Reply: 3GS wheel thread
