3GS wheel thread
#406
Hey everyone, I just picked up some new wheels and am wondering what tire sizes to get.
They are 20x9.5 +38 and 20x10.5 +38.
I entered the information into the tire size calucator on 1010's website and it seems 235/35/20 (f) and 265/30/20 (r) would be within 3% of factory diameter, but since the wheels are semi-aggressive, would you think those tire sizes would minimize on rubbage or do you think I should go with more of a stretch? (such as 225 (f) and 245 or 255 (r) )
#407
I agree your specs even though your wheel is a 1/2 wider your offset is close to 1/4 less aggressive then mine at +22 I sit almost perfectly flush at my ride height, from the ground to the highest point of my fender arch 25 inches. I do have my fenders shaved and don t rub unless I have the wheel turned and hit a bump. I am running a 245/30 in the front which is almost an exact match to factory overall diameter the 235/35 is about 3/4 of an inch larger than my tire I believe
#411
Thanks for the knowledge and suggestions. So it seems the consensus for the front tire size is 245/30/20.
I just wonder if a 225/35/20 would offer more of a "cushion" for the wheels due to a slightly larger sidewall. Overall diameter is about .5" larger with this size.
@lkapimp216 - At your current height and offset, did you rub bad before the fender shave? When you shaved the fronts, were you able to retain the fender liner?
@msgs350 - Thanks, my car is RWD and I'm trying to achieve a nice flushed look
@IXI187IXI - Thanks for the tips!
@username32 - I'm hoping have my Tanabe sustec pro 5 installed soon and am trying to achieve a drop with no gap between the tire and fender. I've seen a 245/35/20 stretched on a 10" wheel before so maybe a 255/30/20 would work on a 10.5" wheel?
Here are some pics of test fitting 20x8.5 +25 and 20x10 +25 with 225/35/20 (f) and 245/35/20 (r):
![Name: IMG_07551.jpg
Size: 61.4 KB](https://www.clublexus.com/forums/attachments/gs-3rd-gen-2006-2011/435660d1501369724-3gs-wheel-thread-img_07551.jpg)
![Name: IMG_0756.jpg
Size: 75.6 KB](https://www.clublexus.com/forums/attachments/gs-3rd-gen-2006-2011/435661d1501369724-3gs-wheel-thread-img_0756.jpg)
Here are the wheels I need tires for:
![Name: IMG_1005.jpg
Size: 115.1 KB](https://www.clublexus.com/forums/attachments/gs-3rd-gen-2006-2011/435662d1501369724-3gs-wheel-thread-img_1005.jpg)
![Name: IMG_1006.jpg
Size: 110.6 KB](https://www.clublexus.com/forums/attachments/gs-3rd-gen-2006-2011/435663d1501369724-3gs-wheel-thread-img_1006.jpg)
#413
Before you guys make a comment about it needs to be lowered and wheels staggered,
it is almost impossible to get a Lexus dealer to lower or try a staggered set of wheels and tires...That said I sold this set to a Lexus dealer and the car lasted less than 2 hours in the showroom before an elderly lady drove it home.
20'' Vossen VVS084 black/machine on 245/30ZR20 Nitto NT-555
![](http://img26.imageshack.us/img26/5554/001gsy.jpg)
![](http://img811.imageshack.us/img811/6746/002ub.jpg)
![](http://img834.imageshack.us/img834/7185/003jx.jpg)
#416
Has anyone ever heard of a tire mounting machine bending a rim? I just had my tires mounted on my brand new wheels and now there is a very slight bend on the lip. When the tires were mounted, the face of the wheel was faced down on the machine. Do you think the 4 hydraulic clamps have enough force to bend the lip?
#417
#419
that elderly lady will love the rough bumpy ride on those 20's.
