why they setup the front little higher then back (245/35/20-275/30/20),does it help anything?thanks
Almost all rear wheel drive cars are set up this way. When you accelerate the rear of the car will drop slightly which is the reason the the slightly lower profile of the tire.
its the same
the 2nd number doesnt mean that a 30 series tires is taller than a 25 series tire. 245/30 means that the sidewall height is 30% of the width of the tire (245mm) just like 275/25 means the sidewall height is 25% of the width (275mm)
Does this button allow us to program the second set on our own without having to go to the dealer & get reprogrammed ?
the button is just a switch so your TPMS computer has 2 different sets of codes stored. it's possible to get them programmed at somewhere other than the dealership but i couldn't find any near my area. i went to a toyota dealership who did it for slightly less than what lexus charged. maybe you'll have better luck.
So I ended up getting SSR LM-9's. I really like the look of these wheels, they also fit well too. Thanks for everyones help and advice. I also thought I'd share some pictures if anyone is looking to go this way as well.
nice rims, good to see someone running the same rims as me haha. whats your wheel spec
Thanks nGeee, I really like the wheels too. They are 19x9.5 front and 19x10 in the rear. Not sure on the offsets though. Do you have pics up of your car? I'd love to see the wheels on your car too.
hey guys. im a new member here and need some help. Will 20x9 +20 and 20x10.5 +20 fit on an 06 GS? if so what kinda modifications am i looking at and tire sizes? any help will be appreciated. Thanks
Suspension: Ten CST set to the bottom ( 1 thread short of the bottom) front and rear
Front: 20x8.5/ +40 offset/ Falken FK452 245/30/20
Rear: 20x10 / +40 offset/ Falken Fk452 275/30/20
NO RUBBING
Wow...I had no idea that 22's would fit without modification!
I think I can now widen my search!
