3GS wheel thread
#1069
Hey guys, I'm a bit new with all this and been reading up on a lot of these wheel threads but still am unsure of what offset to get. I have an 06 gs430(was told there was bigger brakes) and looking to get the Varrstoen ES1.
The specs, I'm looking at are:
F: 20x9 +25
B 20x10 +35
My huge concern is brake caliper clearance and also not looking to get spacers. Any suggestions? Thanks in Advance!
F: 20x9 +25
B 20x10 +35
#1073
Thinking of runing the conto dws it comes in a 285 30 20 I believe..The tire on the cars 20 inch 10.5 vossens were prev a 285 25 20 veristien. Does anyone know if the 30 will work out ok, Id like to move up in the front from a 245 30 20 to a 245 35 20 as well.Its prolly a tad over spec but these band aide thin tires are not very comfortable on the roads around here,and I have 2 dings in the wheels already from pot holes.
anyone know about these sizes in this dsw tire and fitment without rubbing
#1074
#1075
19x9 et 15 225/35 19x10 et 10 235/35/19
Fabulous profounds
Lowered on tanabe sustec pro coilovers
Shaved rear fenders
Front fenders untouched beside removing that metal strip that's held on with 5 screws
Gs300 06
Fabulous profounds
Shaved rear fenders
Gs300 06
#1076
Off topic of wheels for a second. I have the INGS kit too and is highly impressed at how low you have set your car to given it isn't on air-runners.
#1077
Looking to try some conti dsw tires next I know a fe of you have run these as well. want to try 245 35 20 and 285 30 20. I see quite a few run 30 and 25 series instead.Id prefer to have a little more cushion will these sizes fit ok
#1078
#1080
I run 245/35/20 and 275/30/20 DWS. The DWS is a larger tire and the size is at limit of rubbing. So depending on the offset, most likely you will rub like what I did. I had to do light triming of the fender liner to stop the rubbing.
My rears clear fine
Im on an AWD btw
