3GS wheel thread
#1126
Okay I have a set of Asanti wheels that I just picked up. They are 20x9 +25 all around. I drive a lot so I want something I can rotate. Anyway I wanted to know what size tire I should run on these? I'm not lowering the car any keeping it stock ride height for now. In the future I might put some f-sport springs on it. I'm trying not to do any fender mods. But after reading lots of these posts I'm scared I might have to. Any advise I would really appreciate it.
The car is an 08 gs350 rwd.
#1128
Former Sponsor
Hey FloridaKid
The proper tire sizes since your going square
you could do
245/30/20 all around
#1130
Former Sponsor
The front being a 20x9 + 25 offset could be aggressive
Normally on your body GS we would use a 20x9 +38 offset.
so yes i recommend rolling the fenders 100%
as for the tire sizes a 245/30/20 has a overall diameter of 25.8"
a 235/35/20 has a overall diameter of 26.5" which means you will rub the inner liner being that your offset is aggressive.
Are you sure that the offset is correct??
#1131
Thanks for the help.
I just got the wheels and test fit it with out the tires to see if I would clear the front calipers. Sadly they touch so I'm going to have to run like a 5mm spacer which means that I would have to get longer studs. And by adding the spacer to the front make the offset go from +25 to +20. So I'm going to have to roll the fenders for sure now. And I'm a little scared because I heard of people rolling them and it left little dimples in the fender. I don't want that.
#1135
Since you're so concerned about fitment you should have got new wheels that fit the way you want. My car is lowered with staggered wheels and there is no rubbing and I did not need to roll the fenders.
