3GS wheel thread
#1246
235 it's not that stretched. The problem it's that if u go bigger u r going to have to deal with rubbing and having to raise ur car which defeats the point of having coil. I'm on air so I don't have to worry about rubbing but I went with a 235 all around so I can rotate my tire plus it doesn't rub when I'm ridding slammed!
#1248
#1249
I know most everyone has chimed in here, but just to give you one more opinion, I just replaced all my tires with 235/35/20's and haven't had any issues. However, I'm riding stock right now, looking to do coilovers at some point. I changed my tires cause I hit a pothole the other day and blew two tires, I had 225's on before this happen, I was worried about going to 235's but the shop I went too said it would be no problem - they were right.
#1250
I have a set of rims size. Front 20x8.5 offset is 20
Rear 20x10 offset is 25
tires is front 255 35 20
Rear 275 30 20
right now it I can't make full turns and it scrapes all fenders on bumps
any suggestions. ..
Rear 275 30 20
any suggestions. ..
#1251
But then again my rear fenders are completely shaved. I also have Megan Racing Rear Camber Arms x2 and Megan Racing Rear Toe Arm too, running -3 camber in the front and -4 camber in the rear.
I would definitely run 235/35/20 all around for your setup.
My secondary set of wheels are coming soon, I'm going to do 235/40/18 on 18x9.5 +22 and 265/35/18 on 18x10.5 +22.
#1252
Are your fenders shaved or modified? That'll help. Also, are you lowered, if so, on what?
#1253
![](https://scontent-b-ord.xx.fbcdn.net/hphotos-ash4/t31.0-8/10010812_714261328625639_4342857152995650905_o.jpg)
