OEM quality LS-style rear bumper replacement?
Guest
Posts: n/a
i think it's not far out to the sides enough. looks awkward
I'm wondering how these guys get their parts. Are there that many totalled LS's at the junkyard? i gotta go find me some
I have thought of doing the same thing for awhile, last time I checked, the price on the LS' exhaust tips is $68.41 each from the dealership.
Maybe I will buy the tips and go by my buddy's bodyshop to see if they can fit them without major modification on the OEM bumper, hopefully only need to do some cutting instead of repainting!!!
EDIT:
Here are the part numbers: 52106-50011 and 52107-50011. They called them "the extensions," they are $68.41 each.
EDIT:
EDIT:
EDIT:
wholy crap!
you are the man!!!!!!!
thanks for the part numbers.
I couldn't even make out the exhaust tips in the picture:
$140 is chump change!
These olefin plastic bumpers might be moldable with a heat gun. They will def need to be repainted. But i guess you can paint part of it and blend it with the original?...
The bottom of the bumper needs to be rounded out, and then a flexible filler material needs to be plastered on there with mesh reinforcement.
The exhaust pipe has to be bent 2" toward the center too.
Hey DJ
can you photoshop that on the back of a 06 GS without fixing the plastic to fit right? It would give me a sense of what else would need to be done to get it attached and looking pretty
DJ,
The PU bumper material can definitely be molded into shape using a heat gun/torch-this is often how they repair PU bumpers back into shape after a collision.
The whole bumper have to be painted to give the original look.
Looking at both your pics with the OEM single tip vs. LS tip with some level of visual size approximation...I would do the very same thing i did with mine using my C4S 997 tips/Tubi muffler ( remember you helped me decide on this). Hack the exhaust cutout to fit the LS tips---keep in mind, that the muffler can be adjusted to a certain degree (up/down, sideways).
As for the bottom piece, it all depends on the thickness of the LS Tips- if it fits flushed relatively well within the new cutout AFTER adjusting the exhaust can, i wouldn't worry about the bottom piece.
On a different note, that is why i HAD to fabricate my own custom splitter/diffuser so that my dual C4S 997 tips are visually aligned, and it solved the "bottom" piece problem...BTW, the 997 Turbo tip (Lexo LS style) can work with my mod.
DJ,
man, i NEED to see your exhaust.
How much wiggle room (in inches) does the exhaust have toward the center?
yeah, there's a bottom support base that needs to be clamped in and painted black.
i prefer oem look over big cans.
