I'm not under warrenty
was there a stick the use to be in the middle?
Look underneath the tray. On the driver's side there should be a lever that bolts to the underside of the tray. This allows the tray to pivot up when the console is open all the way. I can not tell from you picture, but it looks like this is either broken or not attached. Take a picture of the underside of the tray so I can see if this is the problem.
