Anybody experience the car shaking?
I experience a shake in the car here and there. Of course I can only feel it when I'm at a stop. Maybe my idle rpm is too low. What rpm are you guys at when in drive and at parked?
It doesn't matter if A/C is on or not. It's just a surge that goes through the car making it shake for second, then everything back to normal.
Any help is appreciated.
yes my 07 does this as well. I took it in and they said all was ok but its obvious that the rpm are sitting to low at times. Its usually when the car is cold in the winter. I mentioned this to the infiniti that used to service my G35 and they adjusted the idle with the ECU. Lexus seems lees willing to try this. I am assuming this is an option for Lexus as well
However, when I got my GS3 back - I felt like a man again.
I8ABMR, did the shaking/vibration go away when the ECU was adjusted?
hey Vincent, when you say you have the vibrations all the time, you mean because of you being dropped on coilovers right? if that's the case, maybe it was there before hand like Retro said and it just intensified because of stiffer spring ratio.
Things are weird with this car like the rattles. Before my rattles came when it was cold weather and car is not warmed up. But only when I'm in neutral or parked. No rattles when I'm driving and only happen sometimes when I'm stopped in Drive. What I'm getting at is maybe it has alot to do with rpm.
SamySalmon
02-27-17 12:29 AM
