Spark Plugs
Old 07-27-09, 07:04 AM
THE.K.W.C
THE.K.W.C's Avatar
Default Spark Plugs
Whats the best spark plugs to use on a 2006 lexus gs300 AWD. I read on another site that DENSO FK20HBR11 iridium where the oem ones that had to be used cause other model plugs where to short and burned too hot.
Old 07-27-09, 07:46 AM
jre002
jre002's Avatar
Use the same ones that the dealer uses if you are driving a stock car. You won't see any noticeable benefit from getting anything super fancy or expensive. Just make sure they are gapped correctly and that is it.
Old 07-27-09, 08:28 AM
THE.K.W.C
THE.K.W.C's Avatar
whats the model number
Old 07-27-09, 08:40 AM
stvincent
stvincent's Avatar
just wondering, how many miles do you have on your car? i thought the recommended interval was 120,000 miles..
Old 07-27-09, 11:16 AM
THE.K.W.C
THE.K.W.C's Avatar
I have 64XXXX miles. My parents are going to borrow my car to go to Vegas in so im going to do another oil change, rad fluid flush, spark plug wires and tranny fluid all at once.
Old 07-28-09, 08:07 AM
yano
yano's Avatar
seems like a waste of money.
My dealer said 120k and i guess its a nightmare to change them as well?
Old 07-28-09, 08:22 AM
jre002
jre002's Avatar
I concur. Unless you are experiencing some type of misfiring or other issue as a direct result of defective or damaged spark plugs, you should leave them alone.
Old 07-28-09, 01:10 PM
THE.K.W.C
THE.K.W.C's Avatar
Its only going to cost me about 160$ for all i want to do..and im sure its not as hard as they say, its just going to take some time. Dealer ships always say its not easy so you dont do it your self
Old 07-28-09, 01:12 PM
THE.K.W.C
THE.K.W.C's Avatar
does any one know the oem spark plug model # i dont wanna take one out to find out
Old 07-28-09, 07:25 PM
jre002
jre002's Avatar
lol. You just don't want to listen. Your sparkplugs are fine. No need to change them. You are wasting your time and money.
Old 07-28-09, 08:31 PM
dlieu8989
dlieu8989's Avatar
Use the OEM ones, the threads on them are at least twice as long as regular plugs. If you read the manual, it says somewhere that you should change them every 60K. It has to do with the Emissions warranty. Look at your maintenance books and look at page 53.
http://www.lexus.com/pdf/service/Sedans.pdf
read the fine print at the bottom saying:
" 2 Required under the terms of the Emission Control Warranty"
btw...your car won't have spark plug wires. Super Long Life coolant is good up till 100K before it needs to be changed. Trans service at 60K, highly recommend using Genuine WS ATF.
Old 07-29-09, 12:43 AM
arnieosp
arnieosp's Avatar
Doesn't it say "ES only"?
Old 07-29-09, 06:48 AM
THE.K.W.C
THE.K.W.C's Avatar
so for all you who say sparkplugs are done at 120000mile here you go
72 Months or 60,000 Miles
o Replace engine oil and oil filter; reset reminder light
o Rotate tires1
o Measure thickness and runout of brake rotors
o Measure thickness of brake pads (IS F, LS 460 L
with Touring Package)
o Replace air conditioner filter
o Replace Smart Key battery (all models
except SC)
o Replace spark plugs (GS, IS, LS)
o Replace brake fluid
o Replace engine air filter
o Inspect the following:
___Axle shaft boots
___Ball joints and dust covers
___Body
___Brake lines and hoses
___Drive belt
___Engine coolant (see page 67)
___Engine valve clearance (IS F, SC)
___Exhaust pipes and mountings
___Front differential oil (GS 350 AWD, IS 250 AWD,
LS 460 AWD)
___Fuel lines and connections, fuel tank band and fuel
tank vapor vent system hoses
Additional Maintenance Required If You Drive Primarily Under the Following Conditions
Driving on dirt roads or dusty roads:
o Tighten nuts and bolts on chassis
Driving while towing:
o Replace transmission fluid (ES only; use type ATFWS or equivalent)
o Tighten nuts and bolts on chassis (ES)
___Fuel tank cap gasket
___Manual transmission oil (IS 250)
___Rack and pinion assembly
___Rear differential oil (GS, IS, LS, SC)
___Steering linkage and boots
___Transfer case for signs of leakage
LS 460 AWD)
___Transmission for signs of leakage
Date: _____________________________ Mileage: ____________________________
Notes:
2Required under the terms of the Emission Control Warranty.
inked05 (07-02-20)
Old 07-29-09, 08:14 AM
stvincent
stvincent's Avatar
i retract my statement. you're right.
ES uses the same plugs, yet interval is 120,000.. got me confused..
manual says Denso FK20HBR11.. can you not find one by this? last place to look for might be a dealership..
inspection i presume? i thought we had a sealed transmission that fluid can't be changed..
Old 07-29-09, 10:24 AM
jre002
jre002's Avatar
I stand corrected. I apologize.
But like I said earlier, use OEM.
Quick Reply: Spark Plugs
