How to get AC colder?
Take it from a guy who has a black saphire pearl GS in AZ in the summer. When you start the car you need to open all of the windowns to air the car out and reduce the insane cabin temperatures, then put the system on fresh for the first minute or two then switch it to recycle. I think the color of the car plays a role in how heat soaked the cabin air will be
my service advisor was telling me that cabin temperatures in a car in AZ can get as high as 160 degrees. Seems a bit high, but then again the heat in AZ never ceases to amaze me
You only need to recharge your freon if there is a leak in your A/C system somewhere. Do not add freon to a system that is not leaking. Simply adding more freon will not make your A/C colder if there is no leak.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Other simple stuff... Roll down the windows / roof when you approach the car with the fob and let it air out, make sure you're using recirculate until it gets cool enough.
You might also want to look into other methods of helping keep your car cool. A quality ceramic tint like Huper Optik does impressive things with keeping the UV & heat out of your car.
Even using a sunshield on your window if you don't makes a pretty big difference.
biacs
06-29-17 01:56 PM
