F+R speakers size in the 08 GS, non ML? Need HELP!!!!!!!
I'm putting together boom system in the car and changing out everything, and my searches really haven't turned up much. I've even been to www.crutchfield.com and their results are confusing. I don't want to order the wrong size. This is the first system I'm putting together so I'm very new at the audio.
Already ordered the sub, amp, cleansweep, but I need the speakers and connectors. What brands are good? Leaning towards Polk or Boston Acoustics, but I might even go as far as getting Hertz or Focal
^^ yea, you ask what's good and yes focal utopia is probably one of the best =)
o and go here for speaker size
http://www.marklevinsonlexus.com/overview.asp?model=gs
i would think the ML or non ML GS would have the same speaker size to fit in the same place?
you can fit 5 1/2 and 6 3/4 in both the front and rear doors i would use 6 3/4 you will need to build a new ring outta wood to make it work.... i would also buy some dynamat
The clean sweep is good but I like the Rockford sixty it has 3 pre out not just 2 like the clean sweep im still thinking which one I should get for my Gs
there's not 14 speakers in the non-ML version.
From Lexus.com
Non-ML
Lexus 10-speaker Premium Sound System with Automatic Sound Levelizer (ASL) and in-dash, single-feed, six-disc CD auto-changer
From Lexus.com
Non-ML
ok are u going to run a 5 ch amp for the speakers then a 1/2 ch amp for the sub?
if your running a speaker amp buy
1 pair 6.5 comp = putting the speaker in the door and tweeter on the top right and left of the dash
1 pair 6.5 comp = rear door and oem tweeter location
wou will need to find out the center speaker size as well, and replace it. all this can be wire up to a 5 ch amp. you will then need to run a second amp to power any subs you want to add
Hifiman1
12-20-17 12:15 AM
